Are RIFAs needed for Plus?
68kPlus
Hi,
Just wondering if it's 100% necessary to have C33 and C36 installed on an international Mac Plus AB.
Also, is it true the late Mac Plus' have bleeder resistors? My Plus is from June 1990.
Thanks
IIRC they are not really required, but they are so cheap i will replace them to keep the board more or less original.
You should replace them if you can. They are not there because the Plus needs them, they're there to stop the Plus feeding crap back into the power network and screwing up other devices.
That makes sense. I have 4x RIFAs for my Plus, but I still need more soldering skills :)
Through-hole soldering is very easy. Bruce Rayne has some great tutorials on through-hole and surface-mount. You can also watch Dave Murray (The 8-bit Guy) solder new through-hole caps in a Plus and get the basic idea.
They are definitely recommended, as they're part of a protection circuit, as has been mentioned.
As for the Rifas themselves, you can still buy their modern equivalents. They will even be marked as Rifa, though they are manufactured by Kemet. And no, they are non-polar, so no worries on that front. However, you don't necessarily need Rifa-style caps, you can use any similar X2 and Y2-class film caps, as needed.
There is no polarity to RIFAs, insert them either way you like. The most important bit is getting the right type/class and voltage rating.
I bought these:
They seem to match 100% the original International AB spec.
I'll just chip in and say...
Desoldering is more tricky than soldering although you'll still be fine. I'd but a couple of cheap ebay soldering kits (some clocks or christmas trees or something) and build them up, then practice removing some of the components and putting then back.
On a £2 board it won't matter if it goes wrong.
I did something similar to what you said. I practised through-hole soldering on a no-good board, and I just succesfully did the RIFA recap!
Thanks everyone for the help!
