IIfx C1 Capacitor - Does it always blow?
olePigeon
68040
Both of my IIfxes had the C1 capacitor blow up. If I remember correctly, so did quite a few other users on here. I'm beginning to think that the general recommendation for any IIfx should be to replace the C1 capacitor with a higher rated capacitor. It's possible it can crater the pads, forcing you to use the other set (which is what happened on the NASA IIfx.)
Both of my IIfx had a blown tantalum there. I had to resort to soldering the replacement tantalum to the electrolytic pads. At the time I didn’t think of upgrading the voltage. Likely a very good idea to do. At least 25v I would say.
Thanks guys, now I really do need to unearth my IIfx. Didn't know these were a problem. Looks like it blew spectacularly while under load. Is that magic smoke stain on the logic board?
When someone comes up with a suitable, higher capacity part. That info and supplier part number will be much appreciated. Might it be advisable to upgrade all capacitors or is that a bad idea?Wondering because a marginal spec capacitor is the typical failure point of DuoDock PSUs.
Yeah, this is a known thing. Not sure why exactly it happens but there's clearly a design flaw/fault with IIfx's as many have done this.
That said, I haven't replaced C1 on mine yet...
I don't really know if resistance really matters, but this looks like a very good candidate from just a quick search:
@Pushpull76 It's actually the C1 cap. Looks like C3 from that angle, though.
@joshc My IIfx thread was lost in the forum crash, but I seem to recall the C1 capacitor had something to do with the SCSI BUS. I think when it blows the only thing that happens is that the external SCSI might not work. When mine blew, it caused an unexpected reset. I quickly turned off the power when I heard the pop.
Sure is. The scariest part was that it splattered ash all over my now-not-so-inexpensive Radius 24X card. So on initial inspection it looked like my Radius card blew something up. Then I remembered the C1 cap, so I looked at the motherboard and saw what was left, then gave a huge sigh of relief. 😌
Is C1 still prone to explosion even after recapping the entire board?
I don't thinks so. This is an old tantalum cap, they are very well known to be spicy electronic little friends. Use a valid substitute, especially with higher voltage rate (25volts) as someone already mentioned earlier.
Good to know. My board was recapped before I bought it. Haven’t had any issues with it in the 8+ years of ownership minus swapping the power supply
