Don't forget to consider that it might be an SE with an 030 upgrade card. That machine ID at the top is going to be the one to look for (just in casePrepared my DB25 BlueSCSI with system 6.08 on it and Tattletech 2.17.
Seems the higher versions of Tattletech need at least system 7 or higher to run...
Tested it on one of my SE's, boots perfectly ( while holding cmd/ctrl/shift/del as there is a working haddrive internally).
One thing I noticed, when the internal harddisk is connected but not working properly (have one of those as well), I can't get the SE to boot from the DB25 port, only way is to take of the bucket and disconnect the internal drive.
From what I've seen so far my guts tell me I'm going to see what's below in the picture
I used to keep TattleTale about for older machines, interesting that older versions of TattleTech work on Sys 6.Seems the higher versions of Tattletech need at least system 7 or higher to run...
A PDS upgrade card would indeed be possible, but that wouldn't make it an SE/30!Don't forget to consider that it might be an SE with an 030 upgrade card. That machine ID at the top is going to be the one to look for (just in case)
Didn't know of TattleTale!I used to keep TattleTale about for older machines, interesting that older versions of TattleTech work on Sys 6.
TattleTale - Macintosh Garden
TattleTale provides very complete information about your computer and its system related software. The information can be viewed on screen by category, printed, written to a standard text file, or output in database readable format.macintoshgarden.org
Exactly what I meantbut that wouldn't make it an SE/30!
What OS are you running? Running 6.0.8 instead of 7.x is like an accelerator! Nice and cheap upgrade.I’d be happy to have any increase in speed on mine…as long as it didn’t cost $200!
Accelerator boards or such wizardy doesn't count
Like LaPorta says, don't try this, they're electrically incompatible.Is there any possibility to use a Mobius Speedster LC in an SE?
Can get one relatively cheap, but I seem to remember that the PDS bus of an LC is different to the PDS bus of an SE, eventhough it is exactly the same connector...LC uses a 68020 on the mainboard instead of the 68000 of the SE
Or was it only the orientation of the connector/upgrade board which was different
The Mobius is a 040 anyway, weirdly I seem to recall they had a version for the SE as well (might only have been a 030 in that case)...
SE PDS is basically incompatible with everything else.
I can help you with that...gotta find an LC now
