IIc strange image
Can I see the schematic? You need to trace pin 4, the WE pin, it's got some issues in the write enable circuitry
This for the 16 chip ram logic board A2S4000. I have the A2S4100 that schematic is VERY bad quality and is on page 407-411 of this attached manual. I decided send the entire manual as it could help you.
The signal starts at the TMG chip as 01 pin 14 good solid signal nice form. Goes to R59 then to the 74LS32 pin 4 comes out on pin 6 and is garbage. See the pics. Going in, out and last is at pin 4 on the ram. Seems everything coming out of this 74LS32 is bad garbage.
Awesome, that's exactly what I was looking for, I'd replace that 74LS32.
I hope it’s this but I made a error. This pics and results are with ROM and CPU removed. Does it make different? I can redo with them in socket.
You need all chips in their sockets. This would be potentially caused by the CPU R/W line not being there so it's just floating.
If those readings are from with all chips installed, then I'd say for sure that 74LS needs to be replaced.
Ok here is a full set pin 14 on TMG, one side of resistor, other side resistor, pin 4 in on 74LS32, exit on pin 6, pin 4 ram 1, pin 4 ram 2, pin 4 ram 3, pin 4 ram 4.
The last five are kinda funky to very funky. I'd probably replace that 74ls
Those 5 from pin 6 on 74LS which is the out pin goes to 4 and ram 1 and 2. Ram 3 and 4 I need check as that comes from another source. That is the Aux memory.
Thanks. I just order some but had to use Amazon as I need it delivered tomorrow as I have a friend coming to visit me Tuesday from Miami. I live overseas in the Cayman Islands so it’s hard for me to get parts. I know is not best quality but it’s what i can do in a pinch.
Hey, whatever works! As long as it's a 74LS32 it'll work. Let me know if that fixes it, I think that might be it.
Well I open up my other IIc to probe the chips and I get same results. It seems the keyboard needs to be connected to get the proper signal on pin 4. I will send you some pics shortly. Outside with the kids a bit before they disown me.
Here are the pics for current machine with issues. In order pic 1 is pin 6 on 74ls32. Pic 2 is pin 4 RW on chip 1, pic 3 is chip 2.
Pic 4,5,6 same pins different machine that is working.
