That’s socketed would you mind a ROM dump?
I don’t have any way of doing that.That’s socketed would you mind a ROM dump?
No worries I’ll see what this one has when it arrives.I don’t have any way of doing that.
Not that I know of. This was the case for a lot of Macs - Quadras and IIci as well, I've had both with either black or white NuBus slots. I guess it was just down to parts availability/supplier, perhaps factory location.What I mean is if you look at some iisi"s some have a black slot and some have white. Was there any difference or variation?
Well I'll investigate the chips and what not a bit further still find this an odd little find.Not that I know of. This was the case for a lot of Macs - Quadras and IIci as well, I've had both with either black or white NuBus slots. I guess it was just down to parts availability/supplier, perhaps factory location.
Noticed this on my IIs as well, my IIx had black slots, my current IIfx had white slots, and my IIfx from years ago had black slots.Not that I know of. This was the case for a lot of Macs - Quadras and IIci as well, I've had both with either black or white NuBus slots. I guess it was just down to parts availability/supplier, perhaps factory location.
Nope head melted to the disk its gone.Hard drive is probably fixable - try to see if there is any rubber bumpers on the head assembly that have gone sticky
This is my 5th iisi and I swear they have the worst power supply ever made.The IIsi’s PSU is awful for caps. There’s 2 SMDs on the soft power board but the through-holes made by Elna I believe go bad as well and leak a LOT. A PSU recap will fix a lot of this machine’s issues for sure.
The board on the PVT was 20MHz and the FPU is this.On the PVT IIsi that you have that had a 25mhz CPU, you said it came with a NUBUS adapter card. What is the FPU they installed on that card? Was it also 25mhz?
This one came with the adapter card the 25 didn’t.On the PVT IIsi that you have that had a 25mhz CPU, you said it came with a NUBUS adapter card. What is the FPU they installed on that card? Was it also 25mhz?
