Small board/tab repair suggestions?
Well - this unfortunate mishap occurred. Thinking about JB weld to mate it back together and then either soldering wire from each joint to joint or scraping the solder runs to solder them together. Anyone have any opinions about best method to repair?
Continued work on this - soldered for a temp fix. Drive is seen by my SE drive controller and when I place a disk inside it says its not initialized. It asks me "single or double" and I choose one. Disk won't format and the drive auto-ejects it immediately. I am 30 minutes in to the Branchus Creations floppy restro video (awesome) and noticed that while I do have the microswitch I do NOT have the metal tab circle in the photo attached. Looking for confirmation that this is likely my problem as the drive cannot tell if the disk is write protected or not - correct thinking?
