Hi all, been doing some work to resurrect the portable but only getting as far as the flashing ? disk.
Non backlit, standard power supply putting out 7.52v, I've recapped the board washed and dried (not oven baked tho) New lead acid battery and fresh 9v.
The hard disk was trashed sticky and making horrible noises so will go for a sd solution. Cleaned and serviced the floppy and made a Norton Portable boot floppy.
Startup goes well, bing and onto missing disk, when I insert the floppy it briefly shows a happy Mac does a couple of read noises then spits out the disk. I've also tried a Rascsi on the DB25 with system 6.0.8 on a 40MB Apple drive, holding down Cmnd, Alt, Ctrl, Shift but nothing at all.
Is this likely to be another hybrid related issue? and if you think so where can I test voltages to check?
Thanks all
Thanks all
