Cloning the MicroMac MMXL99 LC-LCII-CC
Has anyone (@Bolle ?) Looked in to cloning this board? I have one I am willing to sacrifice to the cause. Looks like they made one pcb for either 030 or 020 upgrades, and the only active component is a GAL22V10B, for which there is a modern available alternative, the ATF22V10C, which is a sub-$3 component.
That's only a 4 layer board, it would be insanely easy to reverse engineer that PCB
The issue with that GAL is that it contains code, It could be unprotected and my just be able to be read out, but likely it has the code protect bit set and will need some significant effort to either extract the code or reproduce it from scratch
I could clone that board easily, but if the GAL is protected reverse engineering that is beyond my skillset
If you're going through the effort to extract GALs and PALs and whatnot, might as well set your sights on the Presto Plus.
@Bolle has an automagical gizmo that makes reading some protected GAL types doable, but some types are not. Don't remember specifics, but I think it's mostly the DIP series types that would be problematic?
Performer for the compacts is easy enough, don't know about this one, but it'd be a first step step toward PerformarPlus. Comparing that 68020 interface to 68000 IC/SE PDS Performer would be an interesting project in itself. It may be as simple as buzzing the traces for function to see how the interface might be different and working with the 68000 formulas if that GAL refuses to yield its secrets.
22V10s are more difficult to dump. If its simple combinational that could be easy, if it's registered or other complex thing it will need a dump, which may not be possible if it's registered.
Can you trace where the pin1 of the GAL go ?
I researched cloning the Perforner for 68000 Macs with hopes of doing a few crazy projects with it a few years back. Pretty sure you'll find some useful info there:
I had some success cracking 22V10s lately - couldn't figure out yet how to reproduce the results of the method I used consistently.
Yet again it seems to be at least somewhat specific to the exact chip type/speed rating.
max, is that GAL22V10B in DIP package on the crackable list? If its not, I'll bet @Bolle can figure out what it's doing.
Yeah it is which is why I thought of this again
I would be interested it throwing a 22V10 at a gal cracking gizmo I built one of recently and seeing if it's any good at breaking them (it seems to be very effective at cracking 16v8's, I have had mixed success with 20V8's though (and don't have any 22v10 to test it with))
Ooh nice, looks like the red one is more or less the same design as the one @aperezbios has just in a differen't form factor and looks like it would be a "simple" job :)
The green one would more tricky as it has a PAL on it which is not vulnerable to the "glitching" trick (And will in fact be instantly destroyed if you even try it form what I have read!) though I am interested by what it is going with that MT SRAM.....
