Macintosh IIsi Restoration
@flaurencelle I have not! Techknight recommended checking out the corrosion on my board, especially around 245. I was thinking that I could flux up all of the legs and flow fresh solder, and try things again. I just haven't had a chance to revisit the project.
I loved reading through your restoration journey, and seeing all the attention to detail! I do hope you solve the issue with the white display.
I am working on a IIsi as well, and am in the process of replacing caps. For the PSU, it looks like you used a 33uf 35V radial in place of the 56uF 35V cap on Bruce's guide? I only ask because my unit had a 47uF 50V cap in that spot. I doubt someone went in and swapped it before I got in, but I wanted to verify that yours had a different value too. Not sure how much +/-15uF makes a difference!
I had corrosion there too, which i fixed, so i'm scratching my head ...! Which we had more schematics available to help us! I Measured 4V at C5, which seems a bit odd, but again, there was no op-amps on the schematics so hard to troubleshoot... Thanks for getting back to me! If you ever find the solution, let me know, and I'll do the same if I find something!
Hi Garrett, sorry for overlapping your post! Maybe there was different iterations of the power supply. If the capacitor is part of an RC network, then the value might be important. I recapped mine but I didn't even look at the values of the old ones i removed lol!
