Apple Techstep I have almost all of the ROMs here and some info!
I fixed some geometry on the top enclosure and made the lower enclosure too. I even added a little Easter egg. I'll try to print these out in the next day or two to see if they work.
And to clarify, 1 M-bit can work fine with any ROM?
Would AT27C010-70JU-T work for all? There's decent stock of those on Mouser at the moment.
Hey so I made this quick little comparison, as you can see pinouts should match so I think it would work for the 1MB ROM images.
@jajan547 I'm recreating the labels too. Can you post some high quality photos of the Volumes 2-4. Please position the carts as level as possible and use the reticle on your phone to make sure it's level too. I'm trying to nail the kerning as closely as possible to the originals. These will still need some adjustment but are pretty close.
Version 2 geometry works. Just need to tweak the press fit dims to better cope with imprecise 3D printing. Regardless, the enclosure did come together and fits into the TechStep just fine.
here is everything except for CPU Tests Vol.4 I have also provided the labels for the TechStep floppies.
Here's the updated boards. Hopefully dimensional accuracy is still good on the new connector footprint.
I'm waiting to get another board to test with now, should hopefully be this week. I've also ordered a solder stencil this time so I don't just have to spread paste and pray.
The 1Mbit boards have /PGM pulled high for some PROMs that requires it.
Awesome we should be perfect here I’ll order boards and confirm operation and then from there try and tool out how to make some new ROMs for other computers, awesome work everyone I cannot thank you all enough!
