Getting way ahead of myself here, but came up with a pressing question and a request for help.
According to the Portable Devnote the Luggable (Backlits need not apply anytime soon) uses a modified SE ROM and under cursory examination, the changes don't appear to affect what's necessary. Memory mapping is another story, but that serious hurdle can be addressed if and when.
Question: can Compact Virtual, coded for 68030 accelerators to address additional RAM under VM for 68000 equipped Plus SE, etc, be installed on the Portable and load successfully under one System or another without the system suffering a gruesome death?
Help needed here, my Luggable needs work before I can try to get anything running, much less tested. If we can't verify CV compatibility, there's no point in attempting anything fancier than converting the Performer to run at 33MHZ in a Luggable compliant configuration.
Portable seems halfway between the SE and PowerBook 100, accelerators for both are currently on the impossible dream list.
Then again, if someone here is willing and capable of disassembling and tweaking Compact Virtual for use in Portable and PowerBook 100, we've have a real game changer on our hands. [
