PowerBook 140, 145, 145B, 160, 165 LCD Displays
AFAIK 14x are all interchangeable (i have collected a pair lately, so if there are not i will let you know)
maybe the 160x range as well.
Some of these are monochome while others are grayscale. The 145 and 140 displays are the monochrome ones I believe, and the later ones are grayscale. They might still work but I’ll bet the cable is different across them.
140 / 145 and 145 are all 9.8″ 640×400 mono (so probably interchangeable with the cable, several suppliers)
160 and 165 is 9.8″ 640×400 grayscale
This is something I've been meaning to investigate, whether or not it was the on-board graphics or the displays themselves that limited greyscale depth.
There were three different displays used (with corresponding inverter boards) - Rev A (Sharp LM64P51), B (Hitachi LMG5200XTFC), and C (Sharp LM64P58 / Sharp LM64P582). It seems 140/145/145B can use any of the screens, according to various Apple docs - and certainly you see the Rev C screen used in many 140/145/145B's out there.
The Rev B display is different than the other two, with a different display cable and inverter board, and relatively rare; US Apple techs weren't even allowed to replace them with the same part but rather with the Rev C kit instead.
160/165 are *associated* in the repair / maintenance docs only with the Rev C screen. The Rev A and C screens have the same display cable (they have the same Apple PN), same capacitors, but have different inverter boards... however, you do see these displays and boards mixed in the wild.
I haven't been able to find spec sheets on any of these displays to confirm whether or not the Rev A or B screens are in fact strictly 1 bit. When I put a Rev C display (and its corresponding inverter board) in, say, a 145, I only get 1 bit display options, which stands to reason. What I haven't done yet is put a Rev A or B screen in a 160/165 to see if the display limits output, or see what happens. It's on my to-do list.
Well I was looking at possibly picking up a 140 and trying out the display in my 160. I noticed when I was researching the recap on these displays that they have the exact same PCB element and thus the same caps to replace. Thought it might be worth trying at least.
So, display cables are different between screens.
some are thicker, so same shape but the connector is unable to grip the cable tight enough.
Off topic, but would anyone a) know a source for the ACTIVE matrix panel used in the PB180, and b) whether it would work without further hacks in a PB160?
I sold my 180 some years back and have come to regret doing so — but I still have a functional 160. It’s hard to get excited about the 160’s screen, though, even after a recap.
I tried the Rev A (LM64P51) in a Powerbook 160 and I got a usable picture, at least for about 30 seconds. After that the bottom half disappeared, but I think that's a problem with the screen as it came from a very broken machine. The picture was still greyscale and there was no change in the number of greys available in Monitors.
