There are also models for the GeForce 6200 --https://www.thingiverse.com/thing:4659096There are 3D printable fences for the Radeon 7500 to go into the Cube. Not sure if there are other fences for any other cards, since I haven't needed to look...
I'm not sure, to be honest. It's an NVIDIA 6200 (DVI + VGA) that has 128MB RAM. The DVI output works as expected, and I did not have to tape over pins 3 and 11 to make it work in the Cube. Here are some better photos (VGA ribbon cable and port removed):@ried is that the XFX 6200?
I don't think that this is an XFX 6200. From what I have seen online, those models have a black-colored PCB and a green DVI port. I have also seen a PCI variant that has a blue PCB, but it wouldn't be compatible with a G4 Cube. I wonder if this particular GPU was an NVIDIA instead of one that was made by a licensing agreement with a third party?@ried is that the XFX 6200?
I just found this on eBay while searching for a Radeon 7500, which doesn't seem to be available in a Mac variant: https://www.ebay.com/itm/251126702780?hash=item3a785162bc:g:F3UAAOSwh1haBsn4
It's a Radeon 7000 that is supposedly G4 Cube compatible for $25 shipped. I don't love that its description states that sleep mode functionality cannot be guaranteed, but otherwise, this seems like it would be a step-up from the stock GPU.
Anyway, my vague recollection is that with some of the Radeon cards the Mac editions had larger flash ROM chips than the PC versions, so you couldn't flash the PC version with the exact ROM image used by the Mac cards; ROM hackers came up with "lite" versions that would fit without replacing the flash memory but the hack versions would have issues like, well, sleep not working.
Also, FWIW, I've moaned about this before but I'll repeat it: in terms of raw 3D performance the Radeon 7000 is barely a step up from the Rage 128, in a game like Quake it benchmarks like 50% faster at best, which makes it almost a pointless upgrade for OS 9 (if that matters). It might vaguely be worth it for OS X to get Quartz Extreme support, but that's about it.
(I *think* a GeForce 6200 is also mostly useless for OS 9? For an OS X only machine it might be a good choice.)
To be fair, a flashed Radeon 7000 AGP for $19.80 USD! For the price, a passable upgrade for something that'll perform fine for nearly all 3D applications in Mac OS 9. Many PC flashed Radeon 7000 cards had cut down 32K ROMs which I recall has some never used resolution and refresh rate settings removed to reduce the ROM size, sleep issues could happen but not on every machine.
I have plenty of PCs, including multiple with AGP slots, so flashing a card isn't a big deal. The hard part is picking a card to flash in the first place...Sure, I guess for $20 it’s probably a “fair” value for the functionality, most of my issue with it is the somewhat misleading ad copy. (Just come right out and say it’s a flashed card instead of the bogus graphics…) My frank evaluation would still be it’s probably *not* worth upgrading if OS 9 is your main focus, though, because the performance delta between that thing and a Rage 128 really is remarkably small. (The 7000 has all the T&L hardware of a regular radeon stripped out.) For OS X, sure, maybe worth it for quartz extreme. (It’s not the speed difference that enables that, it’s support for arbitrary size textures, the main hardware gimme of the Radeon the 7000 actually supports.)
If you had a machine capable of flashing an AGP card lying around (I think you need to use a PC) a better idea might be to buy an unflashed card that has the DVI port (looks like that’s available for under $20 if you dig around) and see if you can DIY it. DVI/dual head capability would make the mediocre performance a little more tolerable.
