I have an LC III that I cannot get to install a OS. Using a up to date FloppyEmu.
Tried multiple copies of 7.1, 7.1.1, 7.1.2 & 7.5.3 (that were in .dsk or .img format). The installers just keep erroring out. Different versions will error out on different disks.
Can someone share a working copy of 7.5.3? Ideally something they know works on LC III.
I also re-capped & cleaned the board just in case that was an issue (but nothing changed).
The computer is perfectly stable doing everything so I think it may be the OS copies I have are bad or incompatible (I read online lots of ppl have issues with LC III).
If no one has a working copy for LC III, I may manually copy 7.1 OS files to its hardware... then go through upgrade installers.
Or I may need to setup a emulator to make it easier on Windows to extract some zipped .bin files and try some other copies with FloppyEmu.
