At the request of @BadGoldEagle, here are some pictures of my newly acquired Workgroup Server 9150/120.
I don't have one and thinking back about what I've written that may be the cause. I do take care to touch the PSU with my fingers when I open up a machine in order to discharge any body static, but after that, I take no extra precautions. I usually work barefoot, I have a hardwood floor and no jacket on. I wear natural fibres as a rule too. Still, I may very well be the last strain on these old Macs.Re: dying machines. You do have a proper antistatic setup, don't you? If not, get one - they're not expensive, and nicer ones double as small parts holders.
I would love that. I would love to make all of my macs quieter and cooler.I think we need to put together a thread in the Hacks forum that lists all the vintage Mac models, which fans they have (PSUs, case fans, etc.), and the modern silent equivalent. I'd like to keep my IIfx on, but it sounds like a jet plane taking off.
Anytime! You have done great work with the QuadrATX. It makes me wish I had studied engineering.Great pictures and thanks for the plug!
Pity. I would love to upgrade it but I don't want another dead machine. I can live with the fan noise though.I personally would leave it as is.
About studying engineering... I only learned two things (saves you tens of thousands of bucks/euros/francs):It makes me wish I had studied engineering.
I didn't mean that you couldn't upgrade it, I would just leave the PSU alone. What are your plans for it? It already has Fast-SCSI, right? So a SCSI2SD v6 might be in order? What can you install in the PDS slot apart from that HPV card and a couple of accelerators?Pity. I would love to upgrade it but I don't want another dead machine.
Engineering is just applied science. You need have a pretty large background in quite a few areas to understand what is going on and to use that to get things done in your field.About studying engineering... I only learned two things (saves you tens of thousands of bucks/euros/francs):
#1 That you have to learn everything yourself. The grades are only useful to get the appropriate internship in order to find the proper job afterwards.
#2 CAD. The one thing that is useless today in my sector. Sure, it was useful 20 years ago, but nowadays, try to find a job in the automotive industry as a junior CAD designer. Good luck! (that said, it helps a bit with side projects, but again, there's plenty of tutorials on YT to learn CAD at home)
Be vigilant, perhaps obsessively so. I have lots of rules set up to alert me to these things on many international eBay sites and on the local uction sites.My jealousy levels are off the charts!
