Another Quadra 900/950 CD-Bezel (Caddy Style!)
ktkm
I’ve been spending more time with my Quadra 950 recently. After successfully recapping and restoring an internal caddy-loaded 300 drive, I decided it was time to have a CD-equipped tower. But just as for many before me, the bezel-less front became an eyesore. So I decided to design my own.
You can find the STL file at Cults and a couple of my other takes on 3D printed peripherals. However, I could need some help in finding a suitable spraypaint.
Nice mod! I have a question regarding the caddy cd drive. You open the caddy, place your cd and inside it goes? Or do you have to get cds "caddied" from factory? Also, any reason to recap the floppy drive? Mine's dead and I wonder if recap is a must like on older motherboards; that's mostly for when I get my greasy hands on a working unit.
Thanks, and yes, that is correct, just open the caddy and put the CD inside. It is not the most convenient way, but it feels more professional.
Recap is almost always a good idea, but floppy drive failure is usually due to other factors; broken eject gears and headers.
It's just how it's loaded. Your CD is inserted into the caddy, then you insert the caddy into drive and that's it. The original idea behind the CD caddy is that they would be used to store your CDs in. At the time, the caddies were expensive and nobody ended up using them that way. After a few years, they were abandoned in favour of the tray loader.
Yeah, it seems weird that CDs didn‘t just ship in the caddies. Of course they would cost more than a jewel case, but if everyone had done it, the cost would have gone down.
The insane amount of over-engineering to stabilise a loose, spinning CD and matching the laser to the wobble…
The caddy was to keep CDs from getting scratched and made for a simpler method of loading. Early CD software was specialized and not cheap so getting a CD scratched would be expensive to replace. The original CD drives were pretty pricey and the original caddy loading CDR drives were VERY pricey.
You can put a CD in wrong and try loading it and watch it get stuck with a tray loader.
Once prices dropped tray loading was the norm and Panasonic I think it was used the same just stick it in the slot mechanism used in car CD players and also like much later Apple laptops.
