Hello all,
I have been using scsi2sd and mini vmac and transferring images back and forth.
I think I am doing something wrong with writing sd can using dd, because the mac will not boot. When I write the same image file to the same sd card with balena etcher, it works fine.
Could you please tell me if you see something wrong with the following command? Thanks in advance
dd if=image of=\\.\Volume{......} bs=1M
