So I might be SOL here, but I'm going to ask anyway (and hope for a miracle). In an attempt to replace the fan in my SE, I detached the anode from the CRT so I could work on the board. Everything went well. The new fan works. However, when I was reattaching the CRT, the tip from one of the prongs snapped off. I only tested the for a second to see if it might still work but only got a single dot in the middle of the screen. Obviously, I turned it off after that, and I'm not messing with it until I figure out a workable fix. My question is can I remove and replace the flyback transformer on the board with a new one, or do I just need to suck it up and replace the board?
If I can replace the transformer, then what is the part number I should be looking for, or what would make a suitable modern replacement?
