Should work fine. The CPU doesn't matter, the edge connector pinout does. They are compatible between the 5xx line, Macintosh TV, and Color Classics to a degree (CC needs a mod to deal with the higher video resolution). A 5xx to 5xx swap should be straight forward. The only exception is the LC580, this was a late 68k that uses the later 6xx style edge connector, and IDE instead of SCSI for the hard drive.
