hello everybody,
I am in this very strange situation:
my Quadra 700 came with an hard disk which failed after a few weeks. I wanted to try an 80 pin hd (cheaper, easier to find) with this made-in-china adapter: https://it.aliexpress.com/item/4001112495209.html and I got my hands on a 17GB Seagate Cheetah ST318406LC (the label says it's LVD/SE).
Connecting it and turning the Mac on got me chimes of death and sad mac errors 00000F / 0000003 or 000000A, with any possible combination of scsi id (now the HD is on ID 4).
I could boot the Quadra with an external (v5.5 boxed) scsi2sd and low-level format the disk to HFS with FWB Tool Kit, then install MacOS 8.1 - the disk is there, I can see it, it reads and writes perfectly, if I use system picker to pick the 8.1 HD system folder and then reboot, it will boot into 8.1 with no problems, but... if I unplug the scsi2sd and just turn the Mac on, I get the no-disk icon.
How is this possible? what setting or action am I missing?
Any hint or advise is warmly welcome!
Thanks in advance!
Thanks in advance!
