This doesn't look like the simple approach I use. Just install VirtualBox on your PC and test.
I see things about converting VirtualBox to VWware.... but never needed it.
Virtual Box works...out of the box!
https://www.howtogeek.com/125640/how-to-convert-virtual-machines-between-virtualbox-and-vmware/
Not sure what you mean? Debian. .as of the OS of the MacIP VM? A virtual Box image on a VM cluster?
root@macipgw-vm:~# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.1 LTS
Release: 16.04
Codename: xenial
This is how NAT works on the MacIP VM
Release: 16.04
Codename: xenial
Code:
root@macipgw-vm:~# cat /etc/iptables-save
# NAT ROULES FOR MACIPGW. Now active on the MacIPgw VM Ubuntu 16.04 Linux
# Generated by iptables-save v1.4.21 on Sun Feb 28 12:12:33 2016
*nat
:PREROUTING ACCEPT [5981:1556955]
:INPUT ACCEPT [265:46075]
:OUTPUT ACCEPT [314:23800]
:POSTROUTING ACCEPT [5:280]
-A PREROUTING -s 192.168.60.0/24 -i tun0
-A POSTROUTING -o enp0s3 -j MASQUERADE
COMMIT
# Completed on Sun Feb 28 12:12:33 2016
*filter
:INPUT ACCEPT [139:13510]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [75:6546]
-A INPUT -s 192.168.60.0/24 -p tcp -m tcp --dport 23 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 23 -j REJECT --reject-with icmp-port-unreachable
COMMIT
