I'm running Mac OS 7.6.1 on my TAM with a Sonnet Crescendo/L2 G3 500. That's what the machine shipped with and I usually always have a partition with the original OS version for period authenticity. More often than not this is also the fastest option.
Anyway, I'm planning on adding Mac OS 8 and Mac OS 9 on separate partitions and wanted to see which versions TAM owners prefer and recommend. For Mac OS 8 I assume that 8.6 is the way to go to reduce 68k emulation as much as possible. As for Mac OS 9, EveryMac and Wikipedia list the maximum supported version as 9.1, but I get the impression that some TAM owners use OS9 Helper to install 9.2.1 or 9.2.2.
My main motivation for installing something other than 7.6.1 is to use my Sonnet Tango Firewire/USB PCI card, which list 9.0 as minimum system requirements.
