Resurrecting a few 128k/512k boards
LaPorta
68LC040
I've finally got around to sorting through a box of broken logic boards that I inherited. Four or five of them are 128k and 512k boards, so I figured that it would definitely be worthwhile to try and get them going again. I have a 128k that was chip-for-chip upgraded to 512ke, and I want to backdate it to 128k with 400k drive for historical curiosity. The other boards will be available to others once I am done! This is what I built my test rig for: being able to quickly diagnose boards like this:
The majority of the boards are throwing what appear to be RAM-related errors, which, to my research, appears to be quite common with these machines, especially those with original, Apple-screened RAM. All visible errors are one-liners, starting with 04 and one with 03. So, to start, does anyone have a good, reliable source of the 64 and 256 kbit RAM chips these thing take at a reasonable cost?
This is cool! Will be following this thread. :)
That test rig rig is awesome. I think I remember seeing that in an older thread of yours.
Thank you!
For the first round, I ordered 20 of the 64 bit chips for the three 128k boards I have. Hopefully there aren’t more busted chips than that!
If this works well, I’ll get to the 512ks after.
Crap. So I order these things, spend three hours desoldering the one bad chip, and solder in the new one. Nothing.
I look up schematics. Turns out these things are NOT pin compatible with the original RAM! What in the heck gives. How frustrating. Does anyone have any insight into a source of pin-compatible stuff for these? I mean, I can make a breakout board and wire it correctly, but come on.
Here is the pinout from the spec sheet on the order site:
And from the Mac 512k schematics:
Ok so I sorted all this out on paper:
Basically, the ground and 5V pins are reverse...why, I have no idea. So, I went ahead and raised the 8 and 16 pins up, inserted wires into their corresponding holes, and rearranged them. I used a new RAM chip in case I fried the other.EAB05247-CBF2-4830-AC7F-3665EF8ECDC5.jpeg
This arrangement produces the same result:  nothing on startup. No chime, no video, nothing. It may be that these chips just don’t work at all...what do I know about it? I wish I knew of a known-good source. Otherwise I’m kind of stuck here. Open to all suggestions.
That’s crazy that the pin-out is different on them. I figured that was the same on all 64k RAM chips.
Hopefully someone can tell you why it isn’t working, or where there’s a good source for the proper RAM chips. I don’t know, unfortunately.
Yes I was quite dismayed that that was the case. I need to find direct replacements. If I’m successful ill post here but I’d love to just have someone who already knows chime in!
IIRC, Uniserver claimed to have laid in a supply of those chips several years ago.   You might search the forums and see if he mentioned where he sourced them from.
Now that I’m thinking about it, I hope I didn’t fry something entirely. I don’t get a boot chime or anything at all anymore (no CRT image). Why would it not just give me a bad RAM error as before? Wish @techknight were here to save the day as always!
Did you change the RAM chip after you powered it on improperly and then rewired? If not, that chip is dead. You cant reverse polarity on a chip and hope it doesnt die it will die. usually instantly.
As far as the exact RAM, I dont remember off the top of my head. I havent needed to replace RAM in these machines before as most of the stuff I ever worked on was SE and newer.
Yes, I used a different chip in the assumption that I fried the other one. By
my hand drawing at least, does the logic look correct? Also, the pin that the chip lists as N.C., I just kept the pin out of the hole
and soldered it up to keep the +5V continuity path. Was that a mistake?
The Logic board will only chime with good ram all around.
Bad ram is F5 according to the sad Mac error displayed.
No display at all can be an issue with the Analog board
Also I have been using 41256 chips instead, easily available and cheaper.
Works on both the 128 and the 512 Logic boards.
Never had any issue.
