I messed with the centering rings and improved the picture, but there's still larger geometric distortion on the top and bottom right. I'm looking at maccaps guide and tried to rotate them a bit with needle nose pliers but they were hard to move and adjusted things in unexpected ways since they didn't rotate cleanly - you let off the pliers and the picture looks different than when rotating. I could only safely access four of them. Would love to learn more about how to do this, what tool to use, and which ones to adjust for what problems. I'll take a look at that service manual.
The flying toasters in amber are a pretty fun effect:
The flyback has 7 pins, 6 of which are connected to wires. The label itself has 1745 printed on the side, then on the label 95-3574-05 probably as a part number, and below that EIA 343 4 and Made in Taiwan. The cable coming from it is made by Sumitomo, so perhaps that is the manufacturer of the whole thing.
