SyQuest 105 Cartridge
jwse30
So with all this quarantine stuff going on, and me being trapped in my house, I've started tinkering with my old Macs again. They were old and needed tinkering when I bought them 15 to 20 years ago. One of the items I have is a SyQuest drive that has no sticker on the front that is in an APS case.  Inside, the dirve has an APS sticker over what I would guess is a SyQuest sticker that would say what kind of drive it is. A few years ago I stumbled across a 105M disk that fits inside of it, but I don't know if that is the largest size disk this drive will accept.
When I put the disk in, it gives me an "unrecognizable disk, do I want to initialize?". It then gives me the option of Mac or PC formats. Were there other formats, or is this disk either brand new or damaged?
When I put the disk in, a few different SCSI utilities say that it is a 105 Meg drive, but none of them can mount it. I would like to see if there is anything on it before I erase it, just in case someone stored a cure for cancer on it :D
On another note, if anyone happens to have a 230 meg or 270 meg disk laying around, I would like to see what kind of drive this is. I am thinking since it seems to like the 105m disk, that it is a 270 meg drive. If I can get the disk mounted I could either email you the contents of the disk, or burn a CD of them, and then send the disk back if you wanted it.
I like these old drives. I have the 5 1/4 200 Meg one and an EZ135. The 135 has a bit of a problem with the plastic case swelling a bit, making the disk a bit hard to insert or remove, but still works fine. The 200 Meg drive works flawlessly, and I have a spare one, as well as a 44 Meg one too.
J White
What operating system are you running on the Mac you are testing the drive with?  If it's not bad it might be a PC FAT format that isn't supported by the PC Exchange Control Panel you have installed. I think the early versions of PC Exchanged only worked with floppies too. Does the format dialog that comes up show a data size for the format it offers?
Most SCSI utilities can show you drive info like model number. I have both 105 and 270 drives, their models are:
105MB: SQ3105S
270MB: SQ3270S
I think resellers/SyQuest bundled other vendors drivers originally but SyQuest did release their own branded drivers that work all the back to System 7 on all their SCSI drives:
https://macintoshgarden.org/apps/syquest-utilities-401
The Syquest drives probably worked with any computer that had SCSI so the disk could be in a number of formats. I used Syquest drives quite a bit with the Apple II so a lot of my disks are in ProDOS format.
I liked Syquest and collected quite a few. Never had a disk fail on me. Wish I could say the same for Iomega.
I am trying it out on a powerbook 190 running system 7.5.2.  The disk utility I have been using on this machine is Silverlining Lite 2.0. When I select mount, it gives me this screen. I have the mouse clicked to show the drop down menu of possible formats.
I guess if it is some obscure format or not formatted at all, there likely isn’t any data on it that could be useful.
Silverlining shows this as cart 5: syquest sq3105s, which I assumed was the cartridge model number, not the drive.
Thanks for the info.
J White
I like the drives too. I've got three; a 200 Meg 5 1/4" drive, an EZ135, and this 105 Meg one. In my garage, I've also got a 44 M and another 200 M drive. I started using these a long time ago when I found the 200 Meg drive at Goodwill for something like $6 (it was a half off day) and it was in its original box. My wife used the 44 Meg cartridges when she was in college, so I bought it as more of a joke than anything. Now I have a lot of my 68k software backed up on various cartridges and for a while I was using the EZ 135 as the boot drive for an SE.
As for failures, I think I have one EZ 135 disk that may be dead. When I bought the drive it had 7 disks with it. The whole thing sat for at least ten years. In the past month I tried to get it working, and only 6 of them mount. I found backups of 6 of them on my G4 tower's hard drive, so it was likely dead before I received it. I haven't tried to format it yet. Maybe I'll try that today.
J White
The EZ135 is what I used back in the day. I remember it seeming like the smarter choice. And wow was it incredible to have 135MB cartridges considering I'd been living with a 160MB HDD and floppies.
No trace of them in my possession nowadays... eventually Zip disks became ubiquitous and pre-installed on machines and I transitioned over. Must have gotten rid of my SyQuest stuff around then sadly. I do think I ended up with a defective disk or two. But I used them heavily
