Hey, new to the forum here.
I have accumulated quite the vintage Mac collection, and as everyone has experienced, the leaky capacitor issue is a real pain.
Luckily I learned how to remove and solder on new caps. I've been using tantalum caps, and I've got at least 2-3 of the IIci/IIcx motherboards where I recapped them, and they turn on just fine, but once they've warmed up, the just shut off and then power back up. However, they don't power up completely, they immediately turn off again, and on and so on. The cycle starts with the first shutdown/power up I hear the full chime, then it goes quicker and quicker and the chime gets less and less until it's just clicking.
The boards appear to be visually fine. I did not note any extra chip legs corroded or traces damaged more than any other board, and I cleaned with IPA99 the entire board. The power supplies are known good (not recapped), but they work fine with other IIci/cx motherboards.
On the IIci I only have connected monitor, keyboard/mouse, and I'm using an external SCSI (Jaz drive) which works fine on all other machines. On the IIcx I add the required video card. Video card works fine in other machines.
On the IIci I am not using the cache card. RAM has been switched around to rule it out.
When I say warmed up, it's a different amount of time for each machine. The quickest is after 5 seconds or so. The longest runs fine for 10-20 minutes at least until I run a Norton System Test on it, where it shuts off once the hard work on the CPU / video begins.
Before you ask, yes, the power switch is in the horizontal 'I choose when to shut it off' mode, not the vertical 'always stay on' mode. I have rotated it to see if it makes a difference. It was suggested to me to remove and clean the power switch. I don't know if that's the solution here. My guess is there could be a chip that is causing the issue. Thoughts ?
