I have an Apple Lisa 2/5 that was working fine up until about a month ago. The screen started randomly collapsing to a horizontal line and eventually got to the point where it was unusable because it was a horizontal line all of the time. After a few weeks of troubleshooting, I found that the problem was a bad trace on the CPU board that made the vertical sync signal intermittent, but after fixing this trace, the screen now displays nothing at all. The heater in the neck of the tube is glowing, but there is nothing on the screen. When measuring voltages on the video board, I discovered that the 5 volt line is actually around 2.7-3.7 volts depending on when I measure it. I also noticed that the power supply lines that are supposed to be receiving 100 and 300 volts from the video board for the brightness and focus pots are receiving zero volts. I looked on the video board schematic and it looks like these voltages come from the flyback transformer, but I don't know enough about the flyback and how it works to be sure of this. Could this mean that I have a bad flyback or bad circuitry that drives it? Any help would be greatly appreciated!
