From the TAM gang's woes, the 6500 Gazelle architecture board and a compatible Firewire/USB card is difficult to find and targeted by deep pocket TAM types.
Worth noting. For me, I want a 6500/300 specifically for performance comparisons with a beige G3/300, an 8600/300, and just for fun I should probably get a blue-and-white G3/300 in the mix as well, to use as a baseline for thinking about what the performance of each different kind of Mac you could get in 1997 was like, numerically.
I'm not super worried about firewire/USB for most of my vintage Macs, because, to be honest, I have vtools on-site, and that's much faster than USB 1.1 is. Also, I'm I am a 7.6.1-liker, and would probably be running that on such a machine, and 7.6.1 can use neither USB nor firewire, but it can use ethernet, file server, the PC compatibility cards (if those work in the 6500) and the Avid Cinema card (if those work in the 6500.)
It's no skin off my back to get a 6500 and then run it without any PCI cards, or with only a PCI Ethernet card, to be perfectly honest.
I'm actually not sure that the IDE implementation of the 630-6300 and the 6360/6400/6500 is very odd. It's my understanding that it's reliable, performant relative to the SCSI implementations Apple had at the time, and that it fairly handily works well with big disks. (For most people, this will be up to 120 gigs, but I believe johnklos has a 630 or 6200 with a 500 or 750 gig disk in it.)Firewire should be a big improvement over the oddball IDE implementation of the Q630-6500/TAM series, no?
Perhaps ironically, compare with the weird IDE implementations of the Beige and Blue-and-white G3s
Here's the thing. What you are describing: 6400/G3, Video, USB/FW, a bigger IDE hard disk, and CS2 ethernet is [dramatic pause] a Power Macintosh G3, but worse.A 6400 with G3/L2, a nice VidCard for one slot coupled with a USB/Firewire Card in the other probably offers better performance overall than 6500.
The Beige G3 has all that and a much faster bus, onboard 3d graphics that can accomodate 6 megs of VRAM and thus 1600x1200 at 24-bit color, onboard ethernet you don't have to hunt for, no driver oddities, an extra pci slot, a more flexible case with room for more different options, and can run newer software, plus room for loads more ram. (768 megs, vs. 136 megs in a 6400.)
I get that you, and several people, like G3 upgrades, but we shouldn't talk about it in the sense of getting "a better computer than the 6400" because to be perfectly honest, there are loads of better computers than the 6400 to be had all over the place.
I think we should enjoy the 6400 for what it is -- because it's not a very good Power Mac G3.
With that in mind:
My ideal 6400 configs are the stripped out cacheless 180MHz model people would have bought basically just to run clarisworks on, or to replace some older Mac with, and the 200MHz Video Editing Edition, with a PC Compatibility card added in, each running 7.6.1.
Here's the other thing:
All of this highly depends on what software you want to run. The newer you go, the more RAM you need, and the 6400 and 6500 can't hold a lot of that stuff. (136 for 6400 and 128 for 6500, 160 for 4400.) Even the original basic iMac can officially run 384, and unofficially run 512. All Beige Power Mac G3s are known to support 768 megs of RAM, and a PowerMac G3 can run a gig. All "slot loading" iMac G3s can also run a gig of RAM.
So, like, if you want a fast vintage Mac for os8/9 and newer 9-era software, there's plenty of faster and better machines around.
They did well and they were fairly well liked. Their product stack was weird, and as you can kind of tell from the price list, their pricing structure was.... also kind of weird, but each of the clone vendors had weird stuff like that going on.from all accounts PCC did pretty well.
This is 100% true.He later went on to say the status quo of the licensing was more harmful than beneficial...
Traditionally, it's popular to credit The G3 (the iMac in particular) with Apple's re-discovered success in the late '90s, but a lot of different factors really went into that, and one of them was absolutely ending the clone programs.
The clone program arguably extended further than it really should have and because Apple built the boards and supplied the compoments for so many f the different models, often clone suppliers got their machines built and shipped before Apple did, for, reasons I'm not entirely clear on myself. Plus, the clone manufacturers were often quick to adopt slightly faster CPU modules than Apple was using (the 225MHz PowerComputings are a good example of this) while Apple's own machines were still at 200MHz for a couple more months. (Though, 250, 300, and 350MHz versions would follow very shortly.)
The other-other-other thing is that some of the cloners *cough* Motorola *cough* subleased their clone agreement like fifteen times. If you can pull a brand name out of your armpit, that company was slamming StarMax motherboards into PC cases in the mid-late '90s.
I suspect if Apple had negotiated a different kind of contract and if their own distribution and product line made more sense, the program really would have had the intended effect of expanding the Mac market. Instead, what happened is that Apple let the cloners eat its 7000/8000/9000 series lunch and its 4000/5000/6000 series lunch.
The other thing is, I bet a PowerBook clone (say, one built by IBM) would have been super well liked, because laptops was something Apple was really bad at basically from 1994 to 1998.
