Picked up an old IIci from my local junkyard and cleaned it up, recapped the motherboard, and cleaned up a bunch of corrosion from the leaked capacitors with my ultrasonic cleaner. I was able to boot it after that, and it ran for a while. However, I then had issues booting the machine. Messed around with it for a while and it booted again, but the display started flashing on and off rapidly- I could see the desktop as the display flashed on and off, the computer was not rebooting but it seemed to be losing power and regaining it again. I know the issue is not with the monitor as the monitor still works fine. After that particular incident, I recapped the power supply. There was not any visible capacitor leakage inside the power supply. However, after this incident and the powers supply recap, computer will not boot at all now.
What might be going on? Is this a common issue? Any help would be appreciated. I already put a lot of effort into this old machine and now it seems dead for good. I hope I can resurrect it!
