Finally got around to re-capping my Mac SE/30 board, after swapping the CRT from an unhappy Mac Plus and confirming signs of life. Screen came on and I could even boot off my Floppy Emu, though sadly the ADB ports appear to be dead. I knew it could use a re-cap after 30 years (at least 15 of which it was used as a door stop at my old high school). Re-cap went smoothly, and afterwards I cleaned the board with soap and a toothbrush, pressure washed with hot water, then shook and sat to dry overnight. Powered on the next day and I get a chime but no video. I decided to have a go at re-flowing UE8, UF8 and the other chips in that row, along with all the caps I had replaced (a few weren't as flat as they could be). Powered on and not even a chime. Went back for a second pass and ended up breaking a leg off UF8. The speaker chimes again but then blip-blips indefinitely, almost like it's stuck in a reboot loop but doesn't fully chime after the first one.
