PowerLogix UltraCache 1MB UC1MB
Right now I'm mainly curious whether there are any components on the DIMM besides the SRAM chips.    Ignoring resistors and caps, of course.
Here's side A: https://www.dropbox.com/sh/b0htt7cndolqywa/AACmfGGbtGxQ1gmJWpYiRLBXa?dl=0
Here's side B: https://www.dropbox.com/sh/lb9bheme7a0cns4/AAA-xySf03qlM7hie8N_hXjna?dl=0
I couldn't get the auto panorama to work on these... so hopefully you can glean something from them. if you need a better light on that center IC let me know.
It's also a little odd that they used X36 parts.   I don't think there's any parity support on those Macs.
Given the microcontroller mentioned below, could parity checking be implemented on DIMM for whatever reason?
The PowerBoost Pro included a little microcontroller on board that adjusts those CPU card speed setting pins (CLKID_0-2) as one adjusts the bus speed, so that the CLKID pins are always set approrpriately for the chosen bus speed.    The lack of this adjustment on most upgrade cards is probably why most of them won't adjust far off of 45MHz.
If not parity checking per se, might parity checking indicate how the memory is implemented on the eight pads?
I would be interested in seeing a complete scan of the cache.  Apparently, I have forty-eight of the D32-5Is in the attic.   It might be possible to manufacture copies.
Given eight pads, might PowerLogix have been planning 2MB, 4MB and 8MB versions of the UltraCache? They'd certainly not have mentioned that in the press release for PowerCache 1MB. Simpler explanation would be availability of memory capacities/prices at any given time during production, but cache good, more cache better?
Can't see the labeling of the centered ICs. ROM and microcontroller?
Interesting, trag had mentioned a microprocessor being on board? THX.
On the PowerBoost Pro, which is a CPU card, not a cache card.   The PowerBoost Pro is a PPC604e based CPU card with a microcontroller helping with some of the clock adjustment tasks.
I haven't looked up the extra chip on the Ultracache, but it is almost certainly a Tag RAM to complement the static RAM.   That component could be hard to come by...    Nobody seems to manufacture discreet tag RAMs any more.    You can make one out of fast comparators, another SRAM and a little logic....
N341256SJ-12 datasheet
Interesting.   It's just a plain old 32K X 8 SRAM.   No Tag function.  I guess the comparators are on the PPC or built into the memory controller.    It's a fast SRAM, so the 32K X 8 parts I have on  hand at 55ns, wouldn't do the trick.  Sigh.
Huh.  I may have typed to soon.   Looks like I have 457 MCM6206B in the attic.   However, only the fastest speed rating would replace the N341256SJ-12.   Unfortunately, I didn't note down the speed rating in my inventory.  Chances of them being 12ns are pretty low.
Also, still having the same puzzlement I had in this posting:
Near the end of that post, I note that a PCI PowerMacintosh cache module that I examined contains 32K words of cache storage, but only 8K of Tag RAM.   The number of address bits in both should probably match, unless the cache scheme is always storing 4 words at a time.
Happily, your Ultracache also has 4 times as many storage addresses as Tag addresses (32K vs. 128K) so at least there's consistency.
jt, I imagine the extra chip positions on the module are there so that the module could be built from lower density parts.   The example Jessenator has uses two 128K chips.    But they might have built the same module with eight 32K chips.
The fact that there's only room for one set and size of TAG chips suggests that the cache capacity will always be the same on this module, but the same capacity might be built out of varying numbers of different capacity chips.
Yep, that was the simpler explanation I mentioned: use whatever combination of the least expensive memory you can source for those pads at any point while the board is in production. Oh well! :mellow:
