One thought about 7.5.5 vs. 8:
System 7.5.5 officially supports up to a maximum of 4GB volumes/partitions noted here. The page doesn't list specifically what happens on an IDE-having Mac like the 630 or 580, I'll ask @defor if he has guidance on that, at some point.
If you revisit this, I would consider trying the following things:
The other thing you can do to at least improve boot time and memory usage is turn off or throw away extensions not related to things you're doing. I'll have to look, it's probably time for me to pull this system out anyway, but on my 840 with 8.0 or 8.1 on it, I'm down to around 12 megs of RAM used.
- 7.5.5 configured with 3+3+2GB partitions
- Using 7.6.1
Il give your suggestions a go when I drag it out off the back-burner. I must admit, the thought of doing 3 partitions is kinda messy IMHO. I think I'd prefer to stick with 2 (as that's ideal for me with DOS taking up half of the space).
What is really like to find out is how to get the damn CD drive support in DOS!
