Hi again chaps.
I've drawn a blank on this one so I figured you guys are the best people to turn to.
So I have a couple of issues with my 630 that have cropped up since I've upgraded the HD to an 8GB one (2x 4GB partitions).
First one is that it crashes a few seconds after selecting "Shut Down". Not sure what might be causing this, it was shutting down perfectly fine before.
Second is to do with mapping a hard drive to the DOS card.
When selecting "New Drive File" and making a file for the DOS HD (doesn't seem to make a difference what size I make it) and selecting "Initialize Drive File" and saving it on my System 7 booting Partition then going to "Create", it goes to "Preparing drive file" progress window and hangs after about 5%.
Sometimes it will just produce a blank white box after about 10-20 seconds, sometimes the "watch" mouse pointer disappears and sometimes it produces a pale yellow window with a 'picture frame' style outlines around the boarder.
Very bizarre.
Anyone have any thoughts to where I should look? I know the hardware is working fine, I can boot and enter the DOS mode fine, just can't seem to make a drive file.
Very bizarre.
