Apple IIc blinking power light
Might be a possibility, RAM chip are MT4264 right ?
I've read online that I can also use 4164 chips.
Hi guys,
Just received the chips, tried piggybacking but that doesn’t seem to change anything.  :/
Maybe there are specific chips I shall try this method on ?
If you have any idea, please let me know :'(
Thanks
Edit : Piggybacking F18 makes horizontal white bars but that's it
Arths
Problem is you can have more than one faulty unit. Sometimes not easy to troubleshoot, but a slight change can indicate the faulty chip
I’ve changed chip F18 and I now have solid horizontal white bars. Another thing is that I seem to loose composite signal every 2 seconds, maybe a clock issue ?
Have you tried the piggybacking procedure once more  on the remaining chips ? can be frustrating but again more than one chip can be bad.
