Ah! But I might as well buy a 24mhz crystal just for the fun of it . . . unless you've got a better suggestion? [}
] You haven't said if it might be fed to the GS neck board thru the A/B gatekeeper?
Dunno, the card always sounded pretty awesome to me given that I was mired in B&W, albeit in the 1182xwhatever range at that time. Pathetic is in the eye of the beholder. In 1989 I think this was something to behold. By the second rev of the Spectrum/24 series, not so much. The market had moved beyond big virtual desktops to multiple big displays for CAD and DTP had begun to require QuickDraw acceleration. It'll do for this. [
______________________________________________________________________________________________________
I'm getting waaaay ahead of myself here, but is there currently a RAMDAC type part available that's suitable to a GS/30™ card design? In the HDMI output NuBus VidCard thread, the VRAM side of things sounded practical enough, but the back end was a formulaic/done deal kinda thing for digital output from an FPGA. How would the analog side break down in terms of available, off the shelf components for pushing just a single, variable intensity analog feed to the GS neck board? Sounds like a strange beast?
Good question? I don't think I've ever tried to lower the resolution, why would I as a dyed in the wool pixel junkie? In a quick check, neither resolution switching nor QuickDraw acceleration are mentioned in the manual, so I'd say not offhand. It was designed to drive SuperMac 16" and 19" 1024x768 displays which were almost certainly fixed at the 64mhz standard clock frequency. The card was bundled with a 30.24mhz crystal to drive two of Apple's fixed frequency displays. The card dates from 1989 and was geared toward panning around virtual desktop resolutions up to 4096x1536! Slap a 24mhz crystal on it to support MultiSync monitors at 640x480 or a 14.31818mhz crystal for NTSC RGB at 640x480. That last sounds very good indeed now that I've found it in the docs, I was afraid it might not support a low enough clock to output the Compact Mac's 512x342.As I've mentioned before, using a newer card that actually *does* have a programmable frequency generator for the pixel clock would totally eliminate these problems. It's actually kind of pathetic that the Supermac card only has a single crystal on it. I mean, I guess I'm kind of confused again; can you even change resolutions without changing crystals?
