Spent part of the day fixing the old girl up after finding her for $20 at an e-waste place recently:
- Removed all four corner handles and washed them to get tons of dirt and cobwebs out
- Fixed the 'faceplate' that surrounds the optical drive / Zip drive bezels - the interior drive cage had been removed at some point (probably to install the DVD-ROM drive it currently has) but not put back in correctly, so the drives were at a weird angle and the faceplate was crooked and bulging out
- Cleared out TONS of dust and cobwebs from inside the machine with an air blower - I found pretty good evidence that there had been a spider colony inside at one point <shudder>
- Re-seated several cables which had come loose
- Burned and used a Mac OS X Tiger DVD to install a fresh OS onto a secondary "documents" drive which came in the machine
Now that I'm able to boot into an OS (the Mac OS 10.3.x that is on the primary drive isn't bootable - I think the drive is failing), I've found a ton of pics and documents from the girl who owned the machine previously - most of them date back to 2008 at the latest, many quite a bit older than that. I'm going to gather them all up on a flash drive and see if I can contact her on social media - given that the machine couldn't boot at all when I found it, it seems possible she 'lost' all her content before recycling the machine, not knowing her files were still on there. Hopefully she wants the content and I can get it all back to her!
