Is there a FKey that will launch an app? Hard to Google for...
Command-F shortcut doesn't work?
That's a Finder shortcut, not a global shortcut. FKeys, on the other hand, are processed by the Event Manager.
I'm wondering if Apple ever supported Function Keys in OS of yore, do they do so in X?
Inside Macintosh volume V covers the Apple Extended Keyboard and shows how to program the function keys for use in an application.
OK, makes sense. I don't remember the last time I searched a file in any OS pre OS9? What's the difference between the methods and their uses? QuickKeys(?) was bundled with my MAC-101 to enable function key macros. Always thought of the Apple extended as a wast of space in terms of the Function Keys and seeming lack of support for them in the OS.
Wow thanks!  Sometimes these words are hard to search for, glad to have this collective resource (forum) around!
As I was trying to install this I realized FKEYRunApp can make Application (and document) shortcuts!  So thats what I did for Find File.
More background: I've now been able to map CMD-SPACE for "Find File" globally, along with CMD-` for swapping windows, CMD-Tab for switching apps (LiteSwitch), so that when I jump from OSX to System 7 I'm not as lost :-)
Thanks again!
I once had a program called “FunKeys” that would let you set them to whatever you want, but I lost it and haven’t been able to find it..
@BadGoldEagle
isn’t that what the OP wanted?
...Or did he / you want to re assign the command keys?
And, I still use cmd + delete, as well as cmd + shift + delete, all the time.
I think the OP only wanted to use the function keys. I’d like to map Cmd-delete to « move to the bin ». I’m running 7.5.1 so this wasn’t part of the OS yet. Can Funkeys do that?
