Cold absolutely will work against you. You need UV + at least room temperature 72 F/22 C. Those are essentially the two variables you can control intensity of UV and heat. The stronger the UV, the faster and stronger the reaction, up to a point. Also, more heat the faster the reaction will occur, up to a point.No pictures to share on this update, but here's what I've done:
Tonight I'm going to play with the hairdryer and bending the plastic burn back into shape. I messed with it a bit this afternoon and found that while I could slightly soften the plastic, I couldn't really get much to happen. If you have any tips, let me know.
- After letting it sit for 3 weeks, I took it apart, discharged the CRT (no pop), and completely disassembled it
- Cleaned entire case with dishwasher detergent and a toothbrush
- Scrubbed black marks and paint overspray off with a wet rag and baking powder
- Performed full submersion retrobrite under a UV lamp (it didn't do much... I think the cold in my garage inhibits the process), decided that it looks "good enough"
- Ordered new capacitors for the analog board
I have to wait a few days for capacitors to arrive anyway, so I might bring it into the house where it is about 70 F and give them some more time. What's interesting is that it's more white where I scrubbed things off using baking soda, probably due to the slight abrasive nature of the baking soda.Cold absolutely will work against you. You need UV + at least room temperature 72 F/22 C. The more heat you can provide the faster the reaction will occur, up to a point.
Yep, taking the grime and oxidation off with baking soda gave it easier access to the chromophores in the plastic, so it could attack them more easily to reduce the colorI have to wait a few days for capacitors to arrive anyway, so I might bring it into the house where it is about 72 F and give them some more time. What's interesting is that it's more white where I scrubbed things off using baking soda, probably due to the slight abrasive nature of the baking soda.
That would be one desk lamp I would be afraid to get near...Desk lamp too close is my guess.
72 F/ 22 C in chemistry is considered part of what is known as STP for chemical reactions. STP stands for Standard Temperature & atmospheric Pressure. Standard temperature is room temperature, which is defined as 72 F / 22 C, according to chemistry standards. Standard pressure is considered 1 atm, which is what the atmospheric pressure is on a neutral day (Sunny, Blue Sky, Fluffy white clouds) at sea level, which by chemistry standards is considered standard earth atmosphere. Practically every chemical reaction is done at STP (unless the reaction calls for a different set of conditions), so the standard rule for a chemical reaction is a "standard" room temperature of 72 F/ 22 C. So I just picked that as it is the so called "golden standard" for chemical reactions. Essentially any chemical reaction that is meant to be done without special conditions should work well under STP, as a standard assumption.I have to wait a few days for capacitors to arrive anyway, so I might bring it into the house where it is about 70 F and give them some more time. What's interesting is that it's more white where I scrubbed things off using baking soda, probably due to the slight abrasive nature of the baking soda.
I'm curious, what reference do you have for the 72 F/22 C thing? Personal experience is completely valid here.
Wish I had access to a better lab, I could tell you. I could solubalize it and do an HPLC-MS. Guarantee it would tell me for sure.It would be great if we could find out what the OEM sticky solution was.
