I have installed a SCSI2SD in my Macintosh SE along with 4 MB of RAM, but I've been having some trouble with System 7 and resource forks. When I install from floppy disks, at the very end of the System 7 install process I receive a message similar to:
The installation has failed. Your disk may be damaged.
That's paraphrasing, as I didn't snap a photo. There's also a cute "Sorry!" button which restarts the installation. I can't tell from the message whether this is an issue with my SCSI2SD or one of my installation floppies.
Despite the error message, the system DOES boot and seem to work fine... except for system icons and file associations. Applications copied over via floppy disk don't have an icon until I reboot and rebuild the desktop. I have to do that every single time I add an application.
In addition, I've started to use Fetch to download applications, usually in .SIT files. Fetch almost never seems to set the correct Type and Creator. And if it does, when I try to unpack it with StuffIt Expander, all kinds of unpredictable things happen from system reboots to lockups.
Okay, what the heck'n am I heck doing wrong here. Heck!
