SCSI Hard Disk ICON hack
With the Mac Plus I got external Microtech HD enclouser with Maxtor drive, I deleted the partion and reinstalled the drive with modified HD SC Setup 7.3.5 so it has original Apple drivers loaded.
Anyway I lost the HD's original icon wich I want to use again as I copied it on backup drive.
The question is how can I access the hidden parttion with driver to change that icon? Note that prior the System 7 you can not just copy the icon on HD's drive.
A custom firmware icon is usually applied by a 3rd party SCSI utility.  Micronet or FWB can do custom icons.  I don't know if there's specifically a tool for modifying the icon, though.  That'd be pretty cool without having to reformat a drive.
You could also Get Info and copy/paste the icon, though I know that's not the same.
If you deleted the partition and formatted the drive, consider the icon gone.
But you can use ResEdit to create an icon, as it does have an icon editor. Thing is where - the Finder, System or Desktop files?
I found control panel for system software below 7 which can change your HD drive icon, it is called IconMaster.
Check the link below. I also included icons for System 7 which can be just copy/pasted on HD icon or folder.
HDICONS.img.zip
