145B LCD recapped with tantalums
PB145B
68000
Never seen one of these done in all-tantalums before, but it seems to work great! The contrast drifting has almost completely vanished. Once I recap the inverter, it should be perfect. I also noticed that the overall image quality is better.
Yea itll improve the image quality by an order of magnitude. Main reason is the passive matrix LCD requires a high driving voltage. around 40V or so for the sinusoidal signal to keep the crystals from developing a memory effect. If the caps are bad, it distorts that voltage and signal, seriously compromising the image quality.
Very interesting! I knew it improved the image quality by quite a bit, but didn’t really know exactly why. Now I do! :)
