A RAM module having chips on one side or two sides does not really tell you anything definitive. The important question is whether a SIMM is single banked or double banked. Often, chips on one side corresponds with single banked, etc., but not always.
IIRC, it has been well established that the x[x]63n supports a double banked SIMM in one socket and a single banked SIMM in the other socket, for boards with two SIMM sockets. For boards with a single SIMM socket, a double banked SIMM is supported.
The remaining question is what size of bank does the family support? I seem to remember that folks have used 128MB SIMMs in them, indicating that a 64MB bank size is supported. Hardware-wise, 64MB/bank support requires support for 12 X 12 bit addressing in the SIMM slot. The 72 pin SIMM spec. supports 12 address lines, but not all machines that use 72 pins SIMMs support all 12 lines nor all possible addressing modes.
Double banked 32 MB SIMMs, made of two 16MB banks, e.g., require 11 X 11 addressing, and so will be the maximum if the machine only connected 11 address pins in each SIMM slot.
Anyway, if 12 X 12 (ROW v. COL.) addressing is supported, then 64 MB banks are supported, and the single SIMM slot x[x]63n machines support 128 + 4MB = 132 MB RAM and the two slot machines support 128 + 64 + 4 MB = 196MB RAM.
Double banked 64MB SIMMs are an odd duck because they require 11 X 12 or 12 X 11 addressing and many machines don't support that mode.
