Retrobrite and a M0116 keyboard - logo removal?
JonP
I'm going to retrobrite one of my M0116 keyboards and am wondering whether the moulded, coloured Apple logo comes out or not?  There's a small hole behind it in the keyboard frame but pressure in the hole doesn't seem to do much!
Jon.
If you see the little hole then press using a paper clip or some other pointed object that can fit through the hole. The little Apple logo will pop out, store somewhere until you finish whitening then just put it back, that's all.
Thanks Alex, I'll be a little more forceful with it then !
BR
Jon.
