Hoping someone can give me some advice.
Issue
SE/30, no bong, video shows up but the image displayed is that of a static semi random checker board - see attached images
About the machine
- SE/30 no HD
- Removed all old caps, axials and electrolytics and replaced axials with axials and electrolytics with tantalums.
- Old caps had virtually no leaking when I received the board which was shipped in an antistatic bag
- Condition of board, looks clean but was purchased as untested. I only tested after replacing caps.
- Battery did not leak (no battery was included with the board)
What I have done.
Reseated the ROM.
Checked continuity for replaced caps and all pass as far as I can tell.
Reworked solder (reflowed) entire section marked in yellow (see image).
What I have NOT done.
Visually inspected analog board (dong that in a few minutes after discharging CRT)
Rework solder (reflow) the Analog board (potentially might help?)
Reseat RAM
Reseat Socketed Chips (but I don't have a proper tool to remove them)
If you have any advice or need photos of the logic board or sections of the logic board please let me know.
As I understand it this issue as a whole is know as SimasiMac.
View attachment SE30_vid_issue.mov
Issue
About the machine
- SE/30 no HD
What I have done.
Reseated the ROM.
Reseat RAM
