LaCie MO 230 drive for PB 190 or 5300
MO disks are more closely resemble the size of a floppy disk rather than a Zip disk.  Zip is quite a bit larger.  You can actually fit an MO drive behind the floppy bezel and it'll work.  I did just that on my LC.
Nice, I wonder how that might work out for the 1400 bay?
Charadis, I don't see a pic of an interface board on the back of the drive? If there is one, is it interchangeable with the CD-ROM adapter plate? If so a hybrid CD/FDD/MO kluge might work?
FYI, the trick with HDT is to go into the FWB tools control panel and check the removable checkbox for your MO drive's SCSI ID. This tells it to auto-mount MO media. Had to do it with an Olympus MOS360 that I didn't have proper drivers for.
I wish I knew this earlier. I might pull it up someday. I've already removed the Extensions/Control Panel to HDT since I'm not using it right now. Even with the Fujitsu drivers, still seeing the "Eject" option greyed out under Special, but it works fine dragging the disk to Trash.
C, sorry I lumped you in with the haters. Some folks can talk about nothing but the click of death. Sometimes I wonder if they ever used a Zip. I had my second drive replaced under warranty, but like you , I dealt with it for the production glitch it was and moved on.
MO sounds fabulous, was a drive module for the 1400 ever made?
No worries, all is good. :)  Definitely don't remember running into that problem until now. Just surprised that the Zip disk loaded up when I got the right drivers loaded. Was a stroll through memory lane exploring through the disk, like a bunch of buried treasure I forgot I had. Or a lot of money I just saved by spending 15 minutes on Geico dot calm. Except, I can't do anything with most of the files. :cry:  (successfully got two MIDI files out though! Was worth it just for those two)
I've looked but haven't found one. Not sure if it existed. I know Logitec (not to be confused with Logitech!) sold them in Japan for the 5300/3400, but not the 1400. Incidentally, Logitec also made MO kits with bezels for almost all of the PMG4s.
Edit: FYI, the going rate on Yahoo Japan for a USB 2.0 or SCSI MO drive is around $30. Add about $35 for EMS shipping to the US. Sometimes you can find them with *both* USB2 and FW400, but those tend to be on the pricey side.
Funny, I found a Logitec MO drive on Mercari a few days back. Was confused by the logo, and thought it might be a Chinese knock off (nothing against the Chinese. They make amazing product. Like iPhones. But there are also clones and counterfeits that I am well aware of that exist...)
And, what do you know, it's still available. USB/SCSI. I guess 4500 yens is a bit too pricey. :)
https://item.mercari.com/jp/m41272155414/
If they made a Syquest drive for the 1400, you might be able to transplant an MO drive into it from a different module.  I've found that the MO drives are fairly interchangeable with anything Syquest (even their OEM cases.)
I actually read about, and tried looking for the 1400 MO drive out of curiosity. My search only yielded 5300/190 drives, but it appears to be documented that MO drives may exist. If I can find one...
This guy apparently has a MO drive in his 5300c, but that's the closest I've gotten so far
http://www.powerbuch.ch/powerbook-5300.html
Also, found a pdf of a brochure sheet from Fujitsu on the 5300/190 MO drive, attached underneath this. I don't remember the website that I pulled it from though
View attachment fujitsu-230mb-magnetodrive.pdf
Oh yeah, I thought about posting pics on the interface board, but thought the one or two pics I had might just be a waste of time posting. Here are more pics I just took today of the MO drive interface. I may crack open one of the 20x drives I have for the 3400/Kanga. Enjoy
There appears to be an Eject button (SW1), I'm guessing, mounted on the main logic board at the front of the drive. It is hidden by the front bezel, sadly, and there is no way to access it once the drive is reassembled, so I can't test it to be for sure
4500 isn't a bad price. TBH, I'd pay that for one all complete like that. I paid about 3000 for an Olympus SCSI unit with just the PSU, and the same for a Fujitsu USB2.0 unit with the manuals and driver CD, both 640MB.
BTW, other sources for media that I've used are rakuten and amazon.co.jp marketplace sellers. I can read Japanese well enough to place orders on those sites without google translate, though. Mercari's a different struggle for me, though, can't really use that one. I use Buyee for Yahoo, and for online stores like Rakuten, Suruga-ya, and Amazon, I just use my US credit card and fill out the order in Japanese and have it sent to a Tenso forwarding address. Cheaper and quicker than paying someone to do it for me, haha.
I know someone with a Logitec 230M PB3400 MO, he claims it works in his 5300. Don't have the photo of the box, but it said it was for the 3400. I really want to know if a 1400 MO exists or not. There seems to be no reason one couldn't have existed, but yet it seems impossible to find evidence of one existing. And believe me, I've scoured the Japanese-speaking side of the Internet, too.
110% by the way this is completely why we should, as an overall community, not endorse zip.
It was a good solution in the '90s, until we found out it wasn't. It existed in a competitive marketplace, but by the time the clicking happened, nothing (other than MO, actually) was in a good place to take its spot, and even then: What do you do with a large installed base of Zip hardware?
From a technical standpoint, the only good thing about Zip is it "exists" and you can almost always find something Zip related in a local thrift store, just because they were carried everywhere for several years.
Basically, I don't want to hate on Zip for the same reason I don't want to hate on LCs and Performas. It did what it did well enough and it became popular by being inexpensive and good enough. The difference between zip and performas is that the Zip drives and mechanisms went on to have a transferable flaw that could lay waste to large numbers of drives and disks and the data on them, and all the Performas were was a little light on memory expansion compared to high end workstation-aspirational models.
Anecdotally, none of mine ever did the click of death, but I used a relatively small pool of disks and drives in moderately well controlled situations. I imagine the problem was much worse if you were in a situation where you were frequently using public access computers or doing things like swapping media with colleagues and other collaborators. (basically: I got lucky because I was a child when it was happening, and I never developed a need for zip until after everyone else stopped using Zip.)
Not that i know of, unfortunately. It's an oft-repeated point in Apple's datasheet and in articles and history pages about the machine that one could have existed, but it never ended up happening, that I've been able to find.
That's way too strong a statement. Zip is in the DNA of the mid-nineties to early 2k retromac experience. With the release pf the B@W G3 the FDD was phased out entirely by Apple in favor of optional Zip Drive Kits. Zip had replaced SyQuest as the de facto standard for transporting data to service bureaus within months of its release.
Sure there were and will be problems to be wary of, that's all part of the experience. Even something as nearly universal as Syquest in the higher end DTP community pales in comparison to market penetration, much less the direct OS and Hardware support of Apple for the Zip standard.
Ya pays your money and ya takes your chances. Not a lotta chance of losing irreplaceable data using any form of removable drive for temporary transfers.
My 2 cents:
Imho, the Zip drive came too late.
If the Zip drive had been around before CDROM drives started to become standard equipment the Zip drive would have killed the floppy disk.
But CDROMs were already on their way to ubiquity and CD burners and disks came down in price fast enough to make the Zip obsolete before it could become a standard.
I had a Zip 100 but it got very little use as I found burnable CD's cheap enough to be almost disposable.
Even CDRW's were kind of pointless with WORM CD media being so cheap.
The other issue is the software industry never embraced any other media for distribution other than floppies and then CD's.
However, I can certainly see Zip media being useful now for passing around software between vintage Macs that lack CD drives or networking. :)
The other thing, regarding networking, is that not a single Mac in existence lacks networking. LocalTalk exists on all of them. It's not amazingly usable on the 128 and 512k, but those are complete experiences with just a handful of floppy diskettes anyway, and floppyemu can emulate HD20 of, if I remember correctly, various sizes, so that's not where people tend to target their zip efforts.
Notably, Bernoulli predates zip and is faster and much more reliable, but it must have been fairly expensive, for as uncommon and unknown as they are now.
And regarding service bureaus: SyQuest wasn't really "in trouble" until the fairly late '90s, my understanding has always been they'd take whatever you could get the files onto, but yeah, for bigger files, burnable CDs appear to have started looking attractive in the mid '90s. There's at least a half dozen ads featuring them (some just CD-R burners, some combo CD-R and rewriteable phase-change burners), and since tapes were still in common use and people understood how those worked ("via retrospect") firing up toast to master a CD probably didn't seem like such a big deal, given the eventual benefits. I've personally never gotten a lot of excitement out of burning a CD (maybe oddly: I did get some excitement out of my first few burnable DVDs), but I also hated doing it and i only ever did it for data I wanted to "have, but not be in my way."
Zip might be core to your experience, it might even be more common an experience than others, but I wouldn't say it's core to the DNA of the hobby or even the platform. I'd just say it happens to have been common, and it happens to have been convenient. I won't fault you your nostalgia, I just don't think your particular nostalgia should be at the center of how we talk about ways to use these machines. It's one of a few different options, and Zip in particular is one specific type of that option, and it happens to be provably the worst, and I think it's a mistake to try to hide that from people.
Ideally, this would be something we all accepted as reality, and it would be documented on the wiki or on a page. Nobody's trying to erase zip, but it's certainly irresponsible to recommend it without reservation, or even first.
Regarding nostalgia specifically:
You can get the same rush of copying files onto a whirring spinning disc from any of a dozen or two different spinning media standards. If that's all you're after, then zip away. It'll only cost a few bucks and it won't mean that much when it's gone. For almost anything else, every other vintage data storage format is objectively better in any number of ways.
The only reason I'm not removing the Zip drives from my G3, G3s, and 8600, is because I don't have anything else to put in that spot, or blank bezels to put there. Otherwise, even though I have a couple disks, there's no good reason to have them. Networking for this particular era of hardware is even easier, since with add-on cards and big IDE disks, so many of them are viable for use as old Mac servers, let alone doing things like running finely aged vintage debian and windows server virtual machines with AFP/AppleTalk networking. (Honestly, doing that and enabling some of the older UAMs should allow IIgs and Mac system 6/7 to participate too, even on machines without Ethernet, via localtalk bridging.)
I think we under-estimate exactly how easy networking really is.
And, regarding temporary file transfers: that's nice, except how many people are actually doing that with zip? only using it for transfers? It gets advocated for all manner of use cases, to this day. All of the media surrounding it when it was new was basically to do all the same things all the other cartridge formats were actually better at (capacity extensions, high performance storage for media projects, higher capacity for convenient backups). People talk about using them as active boot disks all the time. The entire point of them in the '90s was you'd leave your active data on them and switch between them for projects.
In retrospect, given the asirations people had for Apple and what most of the Macs shipped with built-in Zip drives were allegedly for, I'm surprised Apple chose Zip over literally anything else, even Jaz, as the factory installable option. (Let's remember but ignore that Zip was occasionally cited for delays actually shipping machines, too.) Iomega themselves advertized Zip more for documents, backup, casual uses like saving copies of web pages, maybe software or update installers, old recordings or email archives. Stuff you'd want a big disk drive built into your 6500 for, and stuff you'd want your kid to be able to bring home from the classroom G3 AIO, but as the '90s wore on, multimedia and design projects pretty handily outgrew zip. The advertising in MacWorld for Jaz and SyQuest frequently referenced the fact that large print projects could grow to over a gig.
It's interesting. I personally (as mentioned) never loved burning CDs. It felt wasteful, and honestly still does, even though CDs are as inexpensive as ever. (Just casually, it looks like it's around $0.05/disc in 100 packs.) The process of mastering a CD always bothered me and as such, in my view, it had a place, but that place was different from floppies and zips. It bothered me immensely that CD had "won" and that Iomega tossed in the towel so quickly with Zip 750 in 2003. (Granted: in retrospect, it was probably the best thing for them to do, USB sticks came out that year and addressed the convenience problem handily.
Ironically, I think much of what hurt Zip was Iomega's pricing on it. It looked extremely aggressive, and by the end of the '90s it was less bad than at some other points, but in reality magneto optical usually had both zip and jaz beat on pricing. The drives cost maybe a little more, and the media was way cheaper for MO.
In late 1998 (November, if I remember right, I'm not on the computer with that issue), MacWorld did a storage issue and Zip was around 20 cents per meg, Jaz was close to 30, LS120 was 10. MO was 3. Burnable CDs were a little more than that.
Just to reiterate these two main points on their own:
  • Networking is not as difficult as everyone believes it is. If you can afford a zip drives and some disks, you can probably afford to get some localtalk gear or a serial cable.
  • Zip disks are provably the worst contemporary storage format. It was in its day, too. I have no idea why Apple included it with its own machines, save possibility for the fact that Zip was close to as common in retail stores as  floppy diskette media, compared admittedly to almost all other superfloppy and disk/disc cartridge formats, and even burnable CDs for a long time.
Regarding first-party OS support for Zip: only by way of bundling the necessary drivers, which you can find (perhaps with some inconvenience) or kludge your way around having to use on other formats. And, any machine where Zip support is convenient or where Zips were built in is a machine where it's likely unnecessary or where networking is trivial (i.e. the 7/8/9 and G3+ powermacs all have onboard 10bt+ Ethernet) and a better option for loading software and transferring data to them (CD-ROM drives that are fast, run well, and read CD-RW media fine).
The inconvenience of adding official support for SyQuest or MO on a beige G3 is about the same as what it takes to get Zip running on any 68k Mac running any version of the OS where Zip support wasn't bundled in, so in the absolute best case scenario, adding Zip to my 1400, 840, LC520, PM6100, LC475, or whatever is only more convenient than adding MO or Bernoulli by the way of a single reboot on whatever newer Mac I add the drive to as well.
These processes could be better documented, and perhaps we can call upon the kindness of people like @Charadis and @1400man and @olePigeon who have used these formats to help get this information gathered.
Great stuff.
The one format I wish would have taken off in the US was the SuperDisk. 120MB disks in a drive backwards compatible with 1.44mb floppies.
I use appleshare all the way back to my SE and now my iigs. The iigs had no problem connecting to an OS 9.1 share.
LS120 did get a little love by Dell at least. Various laptops and towers had an LS120 option, such as the Latitude C series or Precision 210 or some Dimension XPSs. Other than that, it was all aftermarket support.
The LS120 drives do make pretty nice plain floppy drives though. They write faster than a normal floppy drive does although not quite as fast as the later USB floppy drives that'll knock a floppy out in 40 seconds.
They used to say about the Warsaw Pact vs. NATO, numbers have a quality all their own. NATO tanks,  aircraft, missiles etc were superior, but badly outnumbered.
Same deal when Apple chose the Zip, ubiquity is nigh on impossible to overcome.
- Zip debuted at $200 in  late 1994 and all but steamrollered every other removable media option.
- PM6400 came out with the internal Zip option two years after the Zip was all but ubiquitous on PC and Mac as the removable of choice.
- CD/RW wasn't introduced until 1997! I didn't jump on that bandwagon until exorbitant drive prices fell to my $400 magic number.
- Apple intro'd the iMac in 1998 with only SJ's Slotloader CD-ROM. Big mistake, CD-RW prices fell and trayloaders function over form became the norm.
- Apple dropped Zip as an upgrade only when CD-RW had become common when the MDD was released
- Networking was unnecessary for the average only one mac user
- Networking was an unnecessary PITA when a PowerBook was added and Zips were common on both.
- Networking a collection is easier and better today for collectors.
- You can throw MO and the rest into that timeline, but it's obvious that Zip hit the sweet spot.
-  Sales/market penetration were negligible by comparison.
- Apple wove Zip into the DNA of the Mac for approx. eight years because there was no other viable option.
- Retailers only keep product that sells on their shelves.
That you can't find a blank bezels for what you feel are Zip infested Macs pretty much proves the point.
I agree with you wholeheartedly that uniserver's internal Zip as HDD shenanigans were misguided. Yes I'm nostalgic about early adoption of the Zip, but it's also something I've used continuously. However you and others are confusing thel timelines or outright ignoring history.
Dunno why this thread got so big. I cant even find these drives. I own both a 5300 and a 3400, cant find a zip nor LS120 or anything.
One thing I think is interesting here is we're definitely having this running discussion about Zip in two different contexts. Your last line about ignoring history (I'm going to chuckle about the irony of that) is interesting, because you've got a few things about in-situ late '90s successes of Zip as a marketed product but you also have some differentcommentary on the practicality of Zip in the '90s and in modern times.
I'm not out to prove that regular people buying Zip drives made a big mistake. I think there's a possibility they could have chosen a better product, but I am also at least a little aware, granted, via back-issues of publications and hindsight analysis from people who were there, that most of why Zip was practical for people was because Iomega strong-armed it into being the only viable choice in a lot of situations. Then, they cashed in by selling the drives at a near loss and selling the media at relatively insane margins.
Other options have always existed, they've always been better, and the value propositions have been different. In a casual or home setting, your neighbor probably doesn't have an MO drive so there are ecosystem reasons for going with Zip in some situations. In a more professional production oriented environment, Zip probably got away with being one of many drives on a given computer or got away with being sold but sitting idle, having mostly been replaced with something a little more realistic to the context. (i.e. someone buys a 9600 that has a Zip in it, but 9600s have like five bays on the front, so their tape, MO, Jaz, or SyJet gets put in the next bay down, or stacked ontop of the machine.)
So, historical issues aside, and you're wrong on several of them, I've included details below, it's worth considering that Zips have a few different problems and they have them at higher frequencies because they were engineered and built cheaply explicitly for the purpose of using a Gillette/razor blade model. Iomega made its money on the sale of Zip disks, not on the sale of Zip drives, which is why at least once below I allude to Iomega having to do some pretty aggressive wheeling and dealing with Apple. My theory here is Apple was receiving the drives almost free and then putting their markup on them, under the speculation that Mac users were generally relatively power-user kind of people within their own classes and you were a little more likely to net a couple of cartridge sales from someone who bought a Performa 6400 than someone who bought a Packard Bell or an Acer, at the time. (To be honest: This perception, whether or not there's any truth to it, is probably why Apple charges for icloud, rather than ever budging on tossing a couple more gigs to the free usage tier, but that's a different discussion altogether.)
So yeah, even though networking was probably impractical if you owned a single Performa 6400 in 1997, there's no reason most people today wouldn't be able to network their Macs together. Of the Macs that had Zip provided by Apple, the 6400 and 6500 were the only ones without onboard 10-base-T Ethernet. They're the only ones you can't pull out of a shipping box and connect to your ISP provided network gateway and start FTPing files or visiting system7today.com or whatever. And, because those systems have PCI expansion slots and Comm Slot 2 availability, it's not like Ethernet is exactly hard to come by. But even if you've got a 6400 and somehow don't have ethernet for it, you can use something as simple as a single serial cable to transfer files with any other beige Mac.
That's why my thesis is use them, carefully, if you've got 'em, but there's no reason to go get 'em. And if you look at completed auctions for Zip equipment on eBay, Zip drives (the ones you'd need to buy for your modern PC/Mac to do the file transfers) are selling for a little more than peanuts. It's almost cheaper to buy a USB floppy drive, a copy of the pro version of Stuffit for your modern computer, and just use stuffit to create archives spanned to 1.4 megs and transfer files that way. It's also almost cheaper to buy a SCSI2SD and an SD card and just mount your Mac volume directly on the desktop of a relatively modern Mac and load files that way. It's a tactic people have used here a couple of times in the past few months.
Magically, almost all of those other technologies except the one (Bernoulli) directly superseded by Zip remained available. Hell, MO technologies were still being made and sold in ~2010, meanwhile the click of death and related problems made Iomega give up on Zip entirely in 2003.
The 6400, 6500, and Beige G3 AIO systems, along with maybe, IDK, the 7300 and the original concept of the beige G3 (where it supersedes the 7300 and 8600 and then there's a further 9600 replacement sitting at the top of the product line) all make sense for Zip, because it's on those machines that relatively casual users do things like save web pages to disks, save copies of emails, keep a few old voicemail recordings around, and so on.
On the 9600 and 8600, and on the Power Macs G3 and G4, it doesn't make an awful lot of sense because that whole time the files were growing and those users needed more or everything, by the nature of what they did.
I'm convinced that the main reason the Zip drive makes sense for the 6500/6500 in particular is because Zips were often the only big data cartridge format you could run to Target or Wal-Mart or an office supply store and buy almost anywhere in the US.
But many of the relevant use cases are fine with a WORM drive anyway, especially on CDs where you cann use multi-session to add more files to the disc later on, and especially in some of the cited use cases such as client deliverables, archiving, and delivery to service bureau. As early as either 1994 or 1995, too, there's drives that do both write-once CD-Rs and write-many 650 megabyte phase change media, giving the benefits of both CD-R and (depending on how the phase change media worked) either MO or CD-RW.
Yeah, actually, the iMac started with a slotloader and I'm pretty sure MCE or a similar company actually built a CD-RW replacement drive for it. The entire concept of the iMac was that eventually Internet-based file transfer (think iDisk) and ultimately USB flash drives would appear. The iMac, interestingly, is probably the biggest breath of life LS-120 ever got. In 1998 when the iMac was launched, not everyone who got one was already into the zip ecosystem, and a zip drive didn't get you your copy of Word 5 on floppies, but an LS-120 got you your floppies and access to a superfloppy ecosystem. Plus it was in January of 1998 that people started to see various aspects of Click of Death start to happen.
CD-RW was common a few years earlier than that. I'm interested in whether or not this is documented anywhere, because the thing we have to remember is Apple themselves never built these drives. They never even really integrated support into their OS. they shipped OS preloads with a few drivers, still written and provided by Iomega, and Iomega themselves built all the drives, and gave Apple the specs for the opening they'd need on the front of the computer.
It's known that Iomega aggressively pursued OEM deals with computer manufacturers. Imation tried this too with LS-120, but wasn't able to secure such a deal with Apple.
By the time of the Power Macintosh G4 MDD, CD-RW had been common on Apple's entire lineup for a few years. DVD-RAM drives had shown up in the Power Mac G4 in 1999 and had been available as a third party upgrade for a few years.  By 2003, PowerBooks and iBooks were shipping with DVD burners installed.
So, I think what happened is Apple kept putting whatever Iomega sent them into their machines literally until the bitter end of the product line.
To add to all of that, it appears an Apple-installed Zip 250 was in fact available for (or at least the MDD had been designed with it in mind) the MDD.
It would've been interesting to see whether or not Apple continued building Zips in after that, but if I recall, Zip-equipped models had had to be delayed a couple of times due to Zip manufacturing or shipping delays, so Apple probably wasn't all that sad to let go of that particular BTO option.
In 1997, sure. Today?
Interestingly! Apple never built or released their own OEM PowerBook Zip modules. It was always VST or Iomega doing the actual building of entire upgrade modules for Zip on the PowerBooks. It was in the ecosystem, but for whatever reason, Apple didn't build or even bundle it on the PowerBooks.
In the US, sure. MO was always ahead by a capacity tier or two. I was looking through a 1994 MacWorld where 650 meg MO was already popular and 128 meg MO was advertised a few times. By 1997, 3.5" MO was up to 640 megs and 5.25 was up to either 2.6 or 5.2 gigs. Costs for the drive were a little higher, but cost for media was a little lower, so MO really relied on someone looking critically at what was there and then evaluating the technical claims made about each and perhaps looking at MO's history into the '80s (the original NeXT system shipped with only MO in its base configuration, for example, so the technology had a bit of a record by the '90s) and make a decision.
Just because MO "lost" to Zip (despite being made for almost ten more years at the tail end of their lives, and being available as an add-on for almost every computer Zip had been available for) in the '90s doesn't mean people are strictly doomed to accept zip and its problems today.
Apple did not weave Zip into the DNA of the Mac. They bundled a product Iomega practically gave to them. It was a smart business move because Iomega was practically paying retailers to keep zip products on their store shelves, because for better or worse, even computer focused retail and even in the '90s didn't always keep everything more technical users might want on hand.
Just because you can't walk into the Wal Mart or even MicroCenter or Fry's Electronics and buy an RDX or an LTO mechanism doesn't mean these things don't exist, it just means they're beyond the tpical markets for those stores. (Interestingly, Fry's and CompUSA and MicroCenter and the like specifically probably did have MO and similar products in stock at their stores, but not every town had one of those. Not every region even had one of those kinds of stores. I know in most of Arizona, you would have had to drive to Phoenix or Tucson to buy much beyond the basics for your computer. (Arguably: you still do today if you want to buy it in person, but buying online is much easier today than it would've been in the '90s.)
I bet if literally any other storage company offered Apple whatever aggressive deal Iomega did, they would have taken that too. Heck, it's not hard to imagine an alt-universe where Sony is a lot more aggressive with MD-Data (that came out in 1992-1993 if I remember correctly) and Apple sells it as an add-on available for or as part of configurations in most bay-having II, Quadra, Centris, LC, and Performa computers. Or, Fujitsu is more aggressive with their MO products, and does the same.
I have found a faceplate for the QS. Even if the person I am going to trade with decides not to, I can just pull the Zip out when it comes time to put something else in that slot.. I'm not angry my Macs have zip. I would just rather put different things in those spots. If it came right down to it, I'm comfortable just running a Zip faceplate with nothing behind it. I ran my blue-and-white that way for several years before I moved a Zip drive out of a PC into it, which is why mine's got a white/beige Zip in it, instead of a black one a little more common for those systems, for example.
On my beige, I have a blank faceplate, I can probably just buy another on eBay or duplicate it with 3d scanning and printing if I really care that much. (Interesting side-idea: also replacing the CD-ROM  with a blank faceplate, for a cleaner overall look, and to fit another hard disk in that drive's spot.)
I'm pretty sure I saw advice to this effect within the last six months. Perhaps not about mounting a zip internally, behind a faceplate or anything.
Hm.
To be honest, and I say this because I've literally been looking things up in period-appropriate MacWorld magazines as I go along, and referring to web sites from the time period devoted to the click of death issue, such as https://www.grc.com/tip/codfaq1.htm, along with some other links I have dropped in, I don't think so.
Just for fun, I've attatched a (not extremely exhaustive, admittedly) comparison chart of removable storage technologies reviewed by MacWorld in November 1998. My previous recollections on the cost per gig were off by a little bit, but were, proportionally, correct. Zip had the highest cost per megabyte. 2GB Jaz was a third that. SuperDisk was pushing a bit over half. MO was a sixth.
The main difference, of course, is MO drives cost around twice what Zip drives did. Not bad. One thing to note about this chart is by the time Imation branded USB superdisk drives started shipping at retail, they were very closely competitive with Iomega's USB Zip drive pricing. (Interestingly: it appears by November Iomega still didn't have anything announced, none of the catalog resellers list a USB Zip drive in this issue, which means you're stuck buying a SCSI adapter or using ethernet or localtalk to move files to Zip, but Imation's own drive was available, and not very expensive.
I also attatched a sidebar about MO technology, it agrees that it basically came down to an ecosystem issue and the American tendency to only look at the first relevant price tag that comes up: the cost of the drive itself. Zip and Jaz won on those fronts, and Iomega marketed them extremely heavily, so they "won" here. As such, if you wanted to work with that installed base, you kind of had to also buy the same kind of drive.
And I attached a page from one of those multipage catalog reseller ads. I looked at all the big names with the multipage spreads and none of them had USB Zip drives. I know that would change in time, but it's definitely an interesting sidenote. LS-120 was very very slow if you look at the benchmarks, but it was probably about as fast as a normal floppy so if you were just using it for floppies and you had a couple of the cartridges for a backup, it likely didn't matter.
Anyway, just because that's the history doesn't mean we're strictly beholden to use what everyone else did at the time. We can easily simply avoid using removable storage on our Macs, in favor of networking, which is also prototypical by the way, MacWorld was always writing about networking, or we can pick storage technologies that meet our needs better. And, for better or worse, I don't know about you, but one of my needs is reliability.
Also, regarding MO's speed: ironically, I hear MO can be sped up a lot by using Mac OS 10.2.0 or newer, which changed the way files are copied from one disk to another to be slightly riskier, but a much more bulk operation, making the actual transfer much faster. That should benefit all storage media, but the effect was probably particularly noticeable on anything MacWorld panned for slowness, since Mac OS itself was responsible for part of the slowness.
I'll just quote the magazine, this is from page 66:
Expandability
Until recently, one of the prime virtues of removable-cartridge technology was that it opened up the golden road to unlimited storage capacity: RUn out of room? Just add another cartridge. But times have changed.
All you have to do is take a quick look at the ads in the back of MacWorld to discover that hard drives are now (relatively) cheap. You can buy a 9GB hard drive for around $600, and 4GB units cost a bit over $300. Do the math: buy a Jaz 2GB drive with one 2GB cartridge for around $400 and then add a three-pack of 2GB cartridges for an additional $300. Compared with buying a $600 9GB hard-disk drive, you've just paid $100 more for 1GB less space.
Hard drives also come out on top in terms of speed. Even the fastest removable storage drive we tested wasn't half as fast as MacBench 5.0's reference drive -- the stock internal drive on the Power Macintosh G3/300.
Most important, remember that hard drives are far more reliable than any magnetic media removable cartridge drive and are designed specifically to be run for extended periods of time. Economies, speed, and safety dictate that if you simply want to expand your storage capability, buy a bigger hard drive. Or two.
Remember: DAT and Travan were still common and imminently affordable at this time. If you bought a Beige G3/300 (8GB stock drive, BTW) and dropped two more 9GB disks into it, it wouldn't at all be unreasonable to go ahead and just start using a CD-R drive or a tape drive as a backup drive. 18GB disks are also available in the ads in this issue, and 40 and 70 gig DLT tape systems were available, so if that was the goal and you had the money, there was no reason to look at external cartridges at all, if your need didn't specifically involve swapping drives with the service bureau or your collaborators.
So, lots of different technologies were available. Mixing technologies wouldn't have been unreasonable, and if your strategy was just to store everything internally, then you'd likely still want something for carrying files across town. It would have been a few years yet before putting something on an online service and retrieving it at your destination (or emailing a link to your collaborator, or working with files directly stored or synced to cloud services) would be practical.
Interestingly, Zip failed a couple years before that, even, and CDs were a huge pain. A large proportion (perhaps as many as had zip drives) or Power Mac G4s had DVD-RAM capability, and in 2003 or 2003, Sony XDCAM/Professional Disc at 23 gigs launched, so perhaps those found some use before people finally moved on. (Plus, USB storage devices, iPods could have file storage spaces set aside, and there were a few other mid-2000s data storage tricks.)
TL;DR: If you want to talk about the history then acknowledge that is in fact 1) history (i.e. what happened, not necessarily what must happen) and 2) the history is more complicated and there's various reasons for what happened and it's not necessarily always what you think (i.e. Iomega practically paid to put zip drives in everyone's hands, and put it in stores.)
@Cory5412 As far as I know, MO drives are plug & play and just need the appropriate driver.  Any Fujitsu drive should work the driver I linked to.  Pinnacle Micro (another popular brand) has their own software, too.  Available on Internet Archive, but I'll upload a copy to my website eventually anyway.  You'll want either the PMO33 or the PVS134.  According the ReadMe file, PVS134 is the newest version and contains both the INIT and formatting utilities built into the Control Panel.  An all-in-one bundle.  It's also designed to work with their MO Drive Juke Boxes.  There're few of them on eBay and rather inexpensive if you can find one locally to pick up.  $85 local-pickup in New York and you can get a dual 5.25" 4.8GB juke box that you can fill up with cartridges and use as a digital library or backup.  Pretty darn cool. :)
@Cory5412 I love looking at those old magazines.  I like that they were using the MO drives as a reference, shame they didn't have Mouse ratings.  The Editor's Pick for the Jaz 2GB Pro cost $50 more for the drive and 2.5x more expensive media than the Fujitsu DynaMO 640.  Since I own a 2GB Jaz drive, I can also tell you that both the drive and the media is much bulkier than a 3.5" MO drive.
Were the MO drives as reference because they're by default lower cost than the products they reviewed?  I'm sure there's some context in the article that accompanied the chart.
As a tangent, Lazy Gamer Review sometimes posts videos of him flipping through old computer and toy magazines.  It's a hoot. :)
OK, what did happen was that the market decided. Iomega didn't invent the InkJet Printer Marketing Ploy, they employed it in removable drives because they were the only mfr. that could. Iomega invented and patented a new disk technology and a novel way to reduce the cost of seeker/head design and a case designed for production that was unbeatable. Cost of entry was fabulous and the average user didn't really need all that many cartridges, unlike their printer. A Zip at home paired with a Zip at work and half or a full dozen cartridges was plenty enough and good enough for even the average consumer to open the wallet.
You can go on forever about shoulda-woulda-coulda in hindsight for any number of reasons and they all amount to exactly jack Zip. The Mac was qualitatively better with a far more advanced GUI OS than PCs until what, the Win 95 mimic of System 7? With the advent of the undeniably inferior Win3.0, the consumer decided and the Mac was relegated to a niche market segment. As you said, Zip was at the very least "good enough," the timing was perfect and the entry price unbeatable. So was Win 3.0. So it goes.
If you have any data to add to the very rough timeline I posted, be my guest, but I posted it in bulleted form for doing so. Tape was for business, the consumer is king and the Zip is what happened. Like it or not.
n.b. Apple had already led itself down a gopher hole with the Twiggy drive in an attempt to capitalize on removable storage patents. They failed, Iomega succeeded.
I did a stream of me looking through one of these old MacWorld PDFs once, it was the one with the Quadra 700 and 900 review, because I wanted some context as to what statements I'e seen about Quadra video performance was like from the time. One of those same issues also had a review of the Radius Rocket, if I remember correctly.
The only thing I can think about as to why MO was listed as "reference" instead of considered as part of the overall shoot-out was because it was considered out of context/band/topic for the article or because they were operating on the presumption that it was given that youd' want a magnetic drive, for the reasons listed in the MO sidebar.
From what I've heard, MO should have been fast enough for the Zip's target market, it was faster than LS-120 and still way cheaper, if you were after a hundred megs or more of portable storage, and you could likely find older disks even cheaper.
MO was pro gear for a production environment review. Zip was a more consumer oriented removable, first, if not the only consumer oriented removable format until CD-RW wrested the market from the Zip in the early 2ks after having steadily reduced Zip's share for about 5 years.
Apples and Oranges.
