On 2018/6/17 at 11:22 AM, Charadis said:
This thread really took off. And I had no idea what MO was! I appreciate all the information! Finally, the drive arrived, and I used some bits of info from everything I've learned from you guys, and got it running on my 3400c. Spent half the day trying to get it to work though. It's close enough.
Missed delivery attempt yesterday, Friday, so had to pick up it earlier today at the PO. Hamada-san (my proxy) did not disappoint with the packaging!
Okay, I got a disk, too.
Actually came earlier this week...
The weight feels substantial. More than 100grams heavier than the Zip drive.
About that... I actually picked up another Zip drive,
@Trash80toHP_Mini
Looks about the same size...
Ummm...I don't know?
I'm guessing this is the amount of items Japan has been exporting to me. Proportional to the amount of money they've been receiving from me, as well. Hmm...
So the disk never seems to mount. No matter how many times I reboot. I upgraded the OS from 8.5 to 9.1, and still no change. At the advice of
@QuadPM I loaded up a copy of FWB Hard Disk Tools (HDT). It recognized it, and it gave me more options to control the drive, but the system still didn't mount the disk.
When nothing is even in the drive, I still get a window popup telling me that the disk is unrecognized by the system. But there is no disk, how can that be, Mac OS? :/ System recognizes the drive okay, and it looks like it picks up there is a Sony disk?? But why no mounting?? Arrrgh
I decided to go a bit extreme, thinking maybe the laser lens is dirty, or something. And, I don't have any floppy drive cleaners, so no worry,
@Unknown_K
Probably my excuse to have a little fun...
Reverse
So the LaCie drive is a Fujitsu drive in a nice LaCie shell.
I wiped down all the areas corresponding to the laser path, and then I reassembled everything back together carefully.
I don't know if the cleaning helped at all. I ran a low-level format through FWB HDT, but it froze at the end of a "successful" format. I finally decided to pull up Apple's disk drive setup, and ran a successful format that finished without freezing. The disk finally mounted after that!!
Here is the thing though...it only recognizes the disk, and mounts it, if you have the disk inserted in the drive at time of booting. No matter what, a dialog box always pops up before fully loading the desktop, saying that the disk is unrecognized, and asking if you want to Initialize it. If a disk is inserted, the two options are "Cancel" or "Initialize." If no disk is inserted, the two options are "Eject" or "Initialize." If you can with a disk inserted, desktop loads and the disk mounts. And if you try to eject, the disk disappears from the desktop, but the drive does not actually eject the disk.
After 7 hours (well, I had lunch, too..), I finally solved the problem...I found software from LaCie on the Macintosh Garden, called "Silver Lining," which loads an "updated" driver to the MO disk. The catch is, the disk has to load at boot in order for the driver to be loaded. Or else, if you try to insert the MO disk after boot, it does not even get mounted.
I posted a demo of how this works on YouTube. At boot, drive scans disk, Silver Lining driver is run, MO disk ejects. Afterward, the drive works normally, with exception of that dialogue box that always pops up before fully loading the desktop.
If anyone who has one of these drives, or similar, and knows the correct extension so that the system doesn't have to rely on having a disk inserted to read the driver, could you chime in, please??
