Mac IIx
I started up the IIx board today.  Re-capped it and found a broken trace on the rear power switch, so it wouldn't power on with the switch, but did with the keyboard. I tried the ROM SIMM from my SE/30 which is really a IIsi ROM (32bit clean) and got death chimes. Swapped the RAM out, and it started up.
I'll have to recap the power supply too, now that I know it runs.
My Mac IIx is alive. It's running System 6.0.8 on a Quantum 230MB hard drive with a Radius Precision Color 24x and an Orange Micro Mac 286 with DOS 3.3.
Recapped the logic board and power supply and added a battery board.
I like the idea of using the Mac II case as a tray table of its own.
If only it had Snow White-inspired legs and a bigger surface for the mouse. If you could make do with a keyboard of less width, a TrackMan Marble might do the trick.
Though it'd also be a little strange to have the Mac IIx without the keyboard it was made for. Hmm.
Hi
i also have a IIx that need some fixes.
So can you please tell me what capacitors types and how many of each type you used for recap ?
thanks
