Sony SuperDrive head spring repair
I recently obtained a couple of compact Macs with Sony SuperDrives.  In both cases the drives wouldn't read disks.  I did the usual servicing of the insert/eject mechanism and both inserted and ejected disks fine, but they still wouldn't read disks.  In both cases the issue with the drives was that the top head was not touching the disk.  I managed to diagnose this by connecting the drive to the computer with the cover off and watching as it tried to read the disk.  Then I simply pressed down on the head with my finger so it would touch the disk.  Once I did that the drive would start to read and write.
This seems to be a common problem with these drives because they use a leaf type spring on the top head.  What typically happens is when the machine is stored away for years on end with no disk inserted, the drive head is held in the open position and this causes the head to stay in this raised position.  The other cause would no doubt be people unwittingly raising the head too far in order to clean between the heads.  This would cause the leaf spring to bend upwards.
I'm glad to say I've found a fairly easy fix to this problem.  I've repaired both drives and they are now working fine.  So I thought I'd write a guide on how to fix this head spring problem.  The fix involves two things:
  1. Bending the leaf spring on the top head back down
  2. Adjusting the internal spring inside the head to further drag the top head down on the disk.
In order to perform these tasks you need to remove the head from the drive.  This is a fairly simple process.  There are two small screws holding the head down.  These screws clamp down the slide bar on the right side of the head (looking from the back of the drive).  Then there are two small card cables which simply pull out of their sockets.  These need to be removed.  Once both those things are done the head can be removed from the drive.
To bend the leaf spring back down again, you need to insert a small screw driver towards the back of the head assembly.  There is a small metal plate where you can rest the screw driver.
Push it in enough to spread the heads apart.  Once that's done you push down gently on the top head.  The screwdriver acts as a fulcrum forcing the spring to be bent back down.
The second fix involves moving the position of the small spring inside the head to increase the tension on the top head.  On the bottom of the drive assembly there are three small adjustment steps that enable you to increase the tension on the spring.  But I've found that even moving the head to the third position is not enough to provide enough downward pressure on the top head.  So my solution was to notch out a fourth position further away.  I used a broken off piece of hacksaw blade to create the new notch.  This increases the tension on the spring enough to provide the required down force.
Internal spring moved to the fourth position.
Once the fixes are done re-install the head and test the drive.  If you find that the top head still needs more downward pressure, you can bend down the top spring several times until it works.
Thanks for this.
You could alternately try to feed a hollowed out short length of flexible plastic pipe around the fastening loop of the spring. The hollowed out flexible plastic pipe is the sort of thing you get when strip the insulation off the end of a small gauge piece of electrical wiring. This may or may not work. I have not tried it.
Careful with this. You can actually throw off the cylinder alignment (head to head) and it wont read anything anymore.
You need to be cautious when bending the top spring, it needs to be done lightly.  I found the safest method was to bend lightly then test and repeat if more tension is required.  Event with the screw driver in place the effect on the spring is very minimal because the top head still doesn't have much room to travel down before it touches the bottom head.  It's quite a safe procedure as long as you're careful.  With the second drive that I fixed the top head had been bent up due to cleaning, it was a good 5mm above the disk.  This procedure fixed it.
Still though. the caution is there. the alignment on these heads are pretty crucial. If that metallic reed slips/stretches/moves laterally, any little bit at all, your toast.
Just be careful.
Just be careful.
As with anything you need to use common sense when working on the top spring, do the procedure lightly and you won't misalign the heads.  Both the drives I fixed are back in their respective machines.  Both machines have had the os re-installed via the floppy, both worked flawlessly.  Let's not forget the drives were toast before the fix.
I've experienced this myself, except I've found that moving that spring in the back up a couple notches (did you know that there are two sets of notches, one at each end?) to be enough most of the time.
c
did you know that there are two sets of notches, one at each end?.
The internal spring has three adjustment steps on the bottom, by default the spring is set to the middle step.  Are you saying there is also adjustment steps at the top of the internal spring?  If so I didn't know that.  How hard is it to adjust it though, it's quite difficult to get to the top of the internal spring?
If adjusting the internal spring alone fixes the drive then all good.  I did try that first.  With both my drives the head was still up too high, it required the screw driver trick.
I wonder if the spring stretches, or if theres some other cause. Just curious.
The internal spring is fine as that's a typical coil spring, the problem is the top spring, that's a leaf spring i.e a piece of sheet metal, and it gets bent upwards.  That's the main problem.  I'd say if the head needs fixing as a result of sitting in the raised position for many years, that should be fixable by adjusting the internal spring only.  If the drive head has been bent up by a person trying to clean the head, that would be where the top spring fix is required.  With both of my drives I think the problem was caused by person trying to clean the head.
The only issue I had with these was those ribbon cables not seating correctly causing the head to come down. I had no clue they could do this too.
