Hi
I own 2 working macs at the moment: a 1Mb Plus running 6.0.3 or 6.0.4 and a 8Mb SE/30 running 7.5.3
I bought the /30 to create floppies for my Plus but now it's become my main 68k machine. I use it for everything, even for actual work
I got some disk images from Slomacuser. The 1984 "demo" disk and the system disk you need if you're trying to run the demo without an HD. (this is because the demo requires a certain version of Macromedia)
Anyway, the disk images work fine, I got them both working on the /30. I created some 800k disks with the images on them, they worked fine on the /30 as well.
BUT neither would work in the Plus, or mount...
System 6 said it needed repairs, so I went ahead and repaired the disks, but it crashed during the operation. The disks I used are good: They work perfectly fine in the /30's superdrive.
Yesterday I tried again as I thought the problem might come from the date the floppies were created: Both computers have no PRAM battery, so every time I start the /30, it thinks we're in 2040... and I've read on Apple's website that the original Mac can't use files created after 6:28:15 A.M. on February 6, 2040. (source: http://web.archive.org/web/19990423125824/http://www.apple.com/about/year2000/y2kos.html yes archives are REALLY useful)
But what about the Plus? That's what I thought, until I changed the date on the /30 and tried it again with no luck.
SOOOO, maybe I'm a complete n00b. But I don't understand why the Plus won't work with those disks!
oh, and I should mention that before I go: the Plus in question acted very weirdly since the day I got it: it came with its own 6.0.3 disquette. It works but not always. Same story with another disk I've bought since, an original system 5 or 4 (can't remember), it worked once and now won't work at all (but will mount on the /30) I tried to repair the disk with McTools but still the same.
I know that's a lot of information in one single message, but I began this "project" two months ago.
:beige: If somebody could help me :beige:
