Hi. I have a PowerBook Duo 230 with problem. When I tired to turn it on, I see on screen a floppy disk icon with symbol "?" What I need to do ? I attached file if somebody understand what i mean. Sorry for my bed english, I'm from Belarus
If the hard drive is there, chances are that it went bad.
Go to the 1400 and see what OS is it running on. If it is running System 7, you might be in luck. the Duo 230 uses a 68030 CPU, not a PowerPC that the 1400 uses but System 7 can run on both.
You can use a USB floppy drive with WinImage or HFVExplorer. 'Burn' floppies from Windows to use on Powerbook. Or, you can use an external SCSI CD drive with the Duo.
